ZCC5143 同步降压直流控制器,替代LM5143
2026年10月19日 17:34    发布者:四维电子
DescriptionsThe is a 65V synchronous step-downDC/DC controller for high current single or dual outputs.The device features an interleaved, stackable peakcurrent mode control architecture for simple loopcompensation, fast transient response, excellent loadand line regulation, and precise current sharing throughparallel phasing for high output currents. 65ns ofultra-short on-time for the high-side switch facilitateslarge buck ratios and supports direct buck conversionfrom 12V, 24V, or 48V automotive inputs to lowervoltage rails, reducing system complexity and solutioncost. The can continue to operate at nearly100%duty cycleas needed even when the inputvoltage drops abruptly to 3.5V. Ultra-high efficiency isachieved byUsing an inductor DCR to detect the current, and ashunt resistor can be used to detect it with highaccuracy. 15uA no-load quiescent current andregulated output voltage extends the operating runtimeof battery-powered systems. The can bepowered by the output of a switching regulator or otheravailable power sources. By utilizing the output of aswitchingregulatoror other available power supply topower the , lower input quiescent current andpower loss can be achievedFeaturesVIN input voltage range: +3.5V ~ +65V1% accuracy, 3.3V/5V fixed or 0.6V to 55V adjustableoutput voltageShutdown Mode Current: 4μA (Typ.)No-load standby current: 15 μA (Typ.)Dual channel or single output multi-phase65ns tON(min) for high VIN/VOUT ratio 60ns tOFF(min) for low voltage dropHiccup mode over-current protectionVCC, VDDA and Gate Drive UVLO ProtectionThermal shutdown protection withhysteresisAdaptive Gate Driver Controlled by Voltage Slew RateSwitching frequency range of 100kHz to 2.2MHzOptional diode emulation or FPWMVQFNP6X6-40 packageApplicationsAutomotive Electronic Systems Advanced Driver Assistance System(ADAS)Infotainment & Instrumentation Systems
