ZCC12030 120V 3.5A 极低静态电流降压芯片替代LM5013
2026年08月27日 18:12    发布者:四维电子
1 DescriptionsThe ZCC12030/E is a non-synchronous buck converterfeaturing a wide input voltage range of 6V to 115V, and isspecifically optimized for applications demanding ultralow standby power consumption. The converter canachieve high efficiency and can support up to 3.5Acontinuous load current with integrated Low RONhigh-sidepower MOSFETs. The ZCC12030integrates a PG pin to indicate whether the outputis within the target range, while for the ZCC12030/E,the PG pin is replaced by an EXT pin instead. TheZCC12030E can achieve much lower standby loss andhigher light-load efficiency via the EXT tied to VOUT.The device employs a constant on-time control mode whichenables a fast transient response. It is compatible with lowequivalent series resistance output capacitors such aspolymer and ceramic (MLCC) capacitors with externalcompensation circuits.The IC incorporates an internal VCC bias supply, whichhelps to eliminate the need for an external VCC capacitorand simplifies PCB layout.The device supports protections including input undervoltage protection, cycle-by-cycle peak current limitation,short circuit protection with hiccup mode, andthermal shutdown protection with auto-recoveryZCC12030/E adopts ESOP8 Package.2 Features•Wide VIN Range: 6V to 115V•10μA Ultra Low Quiescent Current- For ZCC12030/E: 4μA (The EXT pin is tied toVOUT)•Up to 3.5A Continuous Output Current•Integrated 100mΩ MOSFET•1.2V Reference with ±1% Accuracy•COT Mode for Fast Load Transient•Switching Frequency Adjustable 80KHz~1MHz•No External VCC Capacitor is Needed•Low Dropout Mode with DMAX>98%•Power Good Indicator for ZCC12030•Programmable UVLO By EN pin•Internal Soft Start•Cycle by Cycle High Side Peak Current Limit•UVP with Hiccup Mode•ULVO, TSD Protection (Non-Latch)•ESOP8 Package Available3 Applications•High Voltage Post Regulator•E-Bikes, Power and Garden Tools•Motor Drivers, Drones, Telecom•Industry Power Supplies
