ZCC6303恒流驱动替代SY7301
2025年09月19日 18:12    发布者:四维电子
Features
3.0V to 60V Wide Input Voltage
Integrated 250mQ60V Power MOSFET
1.2MHz Fixed Switching Frequency
Up to 95%Step-up conversion efficiency
1mA Light load model efficiency up to 80%
Low than 0.1mAstatic current
Low than 10uAShutdown current
Built-in Cycle-by-cycle current limiting
Built-in thermal shutdown protection
Built-in under-voltage protection
Built-in loop compensation
Built-in soft start circuit
Simple external circuit
2.General Description
The ZCC6303 is a constant frequencymode step-up converter intendedfor small,low power applications.TheZCC6303switches at 1.2MHz and allowsthe use of tiny, low cost capacitors andinductors 5mm or less in height. Internalsoft-start results in small inrush currentand extends battery life.
ThezCC6303 includes under-voltagelockout,current limiting, and thermaoverload protection to prevent damage inthe event of an output overload. TheZCC6303 is available in a small 6-pinSOT-23or ESOP8 package.
Available in a SOT-236 or ESOP8 package
