CML CMX994 100-600MHz直接变换接收解决方案
2012年01月16日 12:46 发布者:1046235000
CML 公司的CMX994是 100-600MHz直接变换接收器,集成了高动态范围I/Q解调器控制增益的宽带LNA,接收器基带部分包括放大器和精密的基带滤波器,整数N PLL和VCO负阻放大器产生本地振荡(LO),工作电压3.3V,主要用在模拟/数字多模式无线电,SDR,数据遥测调制解调器,卫星通信,笛卡尔反馈回路发送器,宽带数据等。本文介绍了CMX994主要特性,方框图,典型应用框图和EV9942评估板主要特性与功能,电路图以及PCB布局图。The CMX994 is a direct conversion receiver IC. It includes a broadband LNA with gain control followed by a high dynamic range I/Q demodulator. The receiver baseband section includes amplifiers and precise baseband filter stages. LO generation is provided by an integer-N PLL and a VCO negative resistance amplifier; an external LO may also be used. LO dividers are provided for flexible multi-band operation.
The device operates from a single 3.3V supply over a temperature range of –40℃ to +85℃ and is available in a small 40-pin VQFN (Q4) package.
CMX994主要特性:
Rx Direct Conversion Receiver
o Direct conversion eliminates image responses
o LNA with gain control
o 100MHz to 600MHz I/Q demodulator
o Precise filtering with bandwidth setting and 1:2:4 bandwidth modes Local Oscillator
o LO synthesiser
o VCO negative resistance amplifier
o LO divide by 2, 4 or 6 modes
o Tx LO Output
3.3V Low-power Operation
Small size 40-pin VQFN Package
Low-power Mode
CMX994应用:
Analogue/digital multimode radio
Software Defined Radio (SDR)
Data telemetry modems
Satellite communications
Constant envelope and linear Rx modulation
Rx function compatible with CMX998
Cartesian Feedback Loop Transmitter
Narrowband: e.g. 25kHz, 12.5kHz, 6.25kHz
Wideband Data
图1。CMX994方框图
图2。CMX994典型应用框图
EV9942评估板
The EV9942 allows the user to investigate all aspects of the CMX994 integrated circuit, which implements a high-performance direct conversion receiver. The evaluation kit also includes additional circuits that may be used to evaluate system performance, a Fractional-N PLL and a high-frequency VCO.
Access is provided to all CMX994 RF, baseband and control signals by either connector or test points.
Test access points are available to accept common test equipments, such as RF and baseband signal generators and spectrum analysers. All signal paths are matched by suitable components. The overall frequency range of this evaluation kit is for RF frequencies between 100MHz and 600MHz, with default operation at 448MHz.
The CMX994 is controlled via its C-BUS serial interface. The PE0002 Interface Card is available separately to support PC-based control of the EV9942. The PE0002 uses ES9942xx.exe PC software, part of the ES9942xx.zip file, which is available from the CML website.
EV9942评估板主要特性:
CMX994 Evaluation Receiver:
o LNA
o I/Q Output
o Selectable Filters
Transmit LO Output
CMX994 Integer-N PLL
Interface for external Fractional-N PLL
19.2MHz VCTCXO
Flexible External VCO
On-board Voltage Regulators
PC Control Interface Available
Interfaces to PE0601, EV9810
or EV9100 Evaluation Kits
448MHz Default Operation
100MHz to 600MHz Evaluation
图3。EV9942评估板外形图
图4。EV9942评估板方框图
EV9942评估板功能:
The EV9942 functionality includes:
Demonstration of a linear direct conversion receiver from RF input to output in I/Q format including:
o I/Q mixers
o first baseband filters
o first baseband amplifiers
o second baseband filters
o second baseband amplifiers.
VCO, Integer-N PLL and divider.
Tx LO Output.
Operation 100MHz to 600MHz (448MHz = default configuration).
19.2MHz VCTCXO.
On-board linear regulators for all necessary power rails.
The C-BUS Interface that allows the card to be connected to a host μController. A PC Interface board is separately available and allows control of all device functions, to support initial test and customer evaluation.
Interface to CMX7163 or CMX7164 evaluation boards (PE0601-7163 / PE0601-7164, not included) to allow demonstration/test of QAM and 2-FSK / 4-FSK demodulation.
Interface to CMX910 evaluation card (EV9100, not included) to allow demonstration/test with GMSK demodulation.
Interface to CMX981 evaluation card (EV9810, not included) allows demonstration of:
o Linear receiver
o Pi/4-DQPSK
In summary, the EV9942 allows the user to create experiments to investigate all aspects of the CMX994 device. The EV9942 is designed to allow user modification, to support the detailed investigation of the user’s specific and different applications. The evaluation platform also includes additional circuits that may be used to evaluate system performance, for example a fractional-N PLL (U8) and a high-frequency VCO (TR2/TR3).
图5。EV9942评估板电路图(1)
图6。EV9942评估板电路图(2)
图7。EV9942评估板电路图(4)
图8。EV9942评估板电路图(4)
图9。EV9942评估板PCB布局图:顶层
图10。EV9942评估板PCB布局图:底层
详情请见:
57618和
57619
CMX994:100MHz-600MHz直接变换接收解决方案
CML 公司的CMX994是 100Mhz~-600MHz直接变换接收器,集成了高动态范围I/Q解调器控制增益的宽带LNA,接收器基带部分包括放大器和精密的基带滤波器,整数N PLL和VCO负阻放大器产生本地振荡(LO),工作电压3.3V,主要用在模拟/数字多模式无线电、SDR、数据遥测调制解调器、卫星通信、笛卡尔反馈回路发送器、宽带数据等。
该器件为单一的3.3V电源,温度范围为-40℃~+85℃,为小型的40引脚VQFN(第四季)封装。
79258
图1 CMX994方框图
79257
图2 CMX994典型应用框图
CMX994主要特性
• RX直接转换接收器
–直接转换消除了图像反应
– LNA增益控制
–100MHz~600MHz的I / Q解调
–精密过滤带,宽设置和本地振荡器1:2:4带宽模式
– LO合成器
–振荡器负阻放大器
• LO分割为2,4或6种模式
– TX LO输出
• 3.3V低功耗运行
•小尺寸40引脚VQFN封装
•低功耗模式
CMX994应用
•模拟/数字多模无线电
•软件无线电(SDR)
•数据遥测调制解调器
•卫星通信
•恒包络线性接收调制
•接收功能与CMX998兼容
•笛卡儿反馈回路变送器
•窄带:例如为25kHz,12.5kHz,6.25kHz
•宽带数据
EV9942评估板
EV9942可以使用户审查CMX994集成电路的所有方面,从而实现高性能的直接转换接收器。该评估板还包括额外的电路(可用于评估系统性能)和一个小数N PLL,以及一个高频VCO。
通过连接器或测试点,可以进入所有的CMX994 RF,基带和控制信号。
EV9942还具有测试接入点,以接入共同测试设备,如射频和基带信号发生器和频谱分析仪。所有的信号路径匹配合适的组件。此评估板的整体频率范围为RF频率,100MHz~600MHz,在448MHz为默认操作。
CMX994是通过其C-BUS串行接口进行控制。 PE0002的接口卡可以单独使用,以为基于PC控制的EV9942提供支持。
79256
图3 EV9942评估板方框图
EV9942评估板主要特性
• CMX994评估接收机
–低噪声放大器
– I/ Q输出
–可选过滤器
•发送LO输出
• CMX994整数N PLL
•外部分数N PLL接口
•19.2MHz VCTCXO
•灵活的外部VCO
•板上稳压器
• PC控制接口
• PE0601,EV9810接口
•或EV9100评估套件
• 448MHz默认操作
• 100MHz~600MHz评估
EV9942评估板功能
•线性直接转换接收器示范,从RF输
入至输出,I / Q格式,包括:
– LNA增益控制
– I/ Q混频器
–第一基带滤波器
–第一基带放大器
–第二次基带滤波器
–第二次基带放大器
• VCO整数N锁相环和分频器
• TX LO输出。
•操作为100MHz到600MHz
(448MHz=默认配置)
• 19.2MHz VCTCXO
•所有必要的电源轨板上线性稳压器
总之,EV9942可以使用户创建实验,以审查CMX994设备的所有方面。 EV9942允许用户修改,以支持用户详细调查具体和不同的应用程序。该评估平台还包括额外的电路,可用于评估系统的性能,例如小数N PLL(U8)和高频率VCO(TR2/TR3)。
