ZCC1001E 100V 1A降压芯片 V1.1
2023年04月10日 17:59 发布者:四维电子
Features9V to 100V input voltage range
1.5A current limit
1A continuous load current
95% Peak Efficiency
400μA operating quiescent current
120V 400-mΩ high-side MOSFET
Peak Current mode control
150 kHz Fixed Frequency
Internal compensation for ease of use
Up to 92% duty cycle
0.8V voltage reference
1μA shutdown current
150ms Hiccup mode short circuit protection
Function
Thermal shutdown Function
ESOP-8 package
Applications
Charger in vehicle
Battery Chargers
Power adapter
Typical Application
Description
The ZCC1001E is a high voltage, non-synchronous
step-down converter operates over a wide range
input voltage 9V to 100V. The ZCC1001E
integrates a 120-V 400-mΩ high-side MOSFET.
The ZCC1001E delivers 1A continuous load
current with up to 95% efficiency. The ZCC1001E
operates with fixed frequency peak current control
with built-in compensation eliminates the need for
external components.
Cycle-by-cycle current limit in high-side MOSFET
protects the converter in an overload condition.
Hiccup mode protection is triggered if the over-
current condition has persisted for longer than the
present time.
The ZCC1001E exhibits protection features that
protect the load from faults like under-voltage,
over-current and over-temperature.
The ZCC1001E is available in an ESOP-8 package.
http://tiebapic.baidu.com/forum/w%3D580/sign=d44231e2d816fdfad86cc6e6848d8cea/3d2527f33a87e950468739a555385343faf2b409.jpg?tbpicau=2023-04-12-05_77149640fd54af88acc817434cd33de1
