一级代理奇力VAS1106A,线性可控硅调光芯片,无频闪应用
2023年02月08日 10:10 发布者:五月的枫
芯片介绍:The VAS1106A is a constant current driver designed to be compatible with TRIAC dimmers. A string of series/parallel LEDs is tapped at the Drain of integrated high voltage switch. The LED current is programmable and kept constant by a current source.The VAS1106A includes a bleeder circuit to ensure proper TRIAC operation by allowing current flow while the line voltage is low to enable proper firing of the dimmer.The device has an input voltage detecting circuit improves PSRR performance when AC line voltage varies.
原厂代理有保障!联系方式:刘先生,18038067596(可免费申请样品测试)
