Industrial wireless AP/IPQ4019/IPQ4029 OpenWrt QSDK 2.4/5G dual bands 802.11ac
2022年12月06日 15:29 发布者:wallyswifi
Industrial wireless AP/IPQ4019/IPQ4029 OpenWrt QSDK 2.4/5G dual bands 802.11acDescriptionDR-AP40X9-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);1 x Enclosure.Dipole antenna■ 2 x 2.4G&5G Antenna■ 5dBi 2.4GHz/5Ghz■ SMA Plug interface■ Plastic rod of black■ RoHS complianceEnclosure■ Dimension: 132x 119 x 34 mm■ Aluminum alloy material■ Support WallysDR40X9
Absolute Maximum Rating
ParameterRatingUnit
Supply Voltage24V~48V
Operating Temperature Range-40 to +70oC
Storage Temperature Range-45 to +105oC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
SymbolParameter
CPUIPQ4029/IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet2xRJ45
SFP connector1xSFP fiber module connector (optional)
3G/4G connector1xminipcie 3G/4G connector support with two sim card
USB connector1xUSB 3.0 connector
POE24V~48V passive POE
DC Jack24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR256MB~512MB
Radio TX Specifications(5180MHz-5825MHz)
Operating ModeData RatePowerTolerance
1 Chain2 Chains
802.11a6 Mbps27dBm30dbm±2dB
54 Mbps23dBm26dbm±2dB
802.11n HT20MCS0, MCS826dBm29dbm±2dB
MCS7, MCS1522dBm25dbm±2dB
802.11n HT40MCS0, MCS825dBm28dbm±2dB
MCS7, MCS1521dBm24dbm±2dB
802.11acMCS0, MCS10,MCS2025dBm28dbm±2dB
MCS9,MCS19,MCS2919dBm22dbm±2dB
Radio RX Specifications(5180MHz-5825MHz)
Operating ModeData RateSensitivity
802.11a6 Mbps-96dBm
54 Mbps-78dBm
802.11n HT20MCS0, MCS8-93dBm
MCS7, MCS15-73dBm
802.11n HT40MCS0, MCS8-90dBm
MCS7, MCS15-70dBm
802.11AC HT40MCS0, MCS10,MCS20-90dBm
MCS9,MCS19,MCS29-67dBm
802.11AC HT80MCS0, MCS10,MCS20-88dBm
MCS9,MCS19,MCS29-62dBm
Radio TX Specifications(2412MHz-2482MHz)
1 Chain2 Chains
802.11g6 Mbps27dbm30dbm±2dB
54 Mbps25dbm28dbm±2dB
802.11n HT20MCS0, MCS826dbm29dbm±2dB
MCS7, MCS1525dbm28dbm±2dB
802.11n HT40MCS0, MCS826dbm29dbm±2dB
MCS7, MCS1524dbm27dbm±2dB
Radio RX Specifications(2412MHz-2482MHz)
802.11g6 Mbps-96dBm
54 Mbps-78dBm
MCS7, MCS15-73dBm
MCS7, MCS15-70dBm
Version
ItemInformation
DR40X9-1CPU is IPQ4019
DR40X9-2CPU is IPQ4029
LED & GPIO header
ItemInformationNote
1PWR LED
2Eth1 LED
3Eth2 LED
42.4G LEDGPIO32
55G LEDGPIO50
6Strength LEDGPIO36
7Strength LEDGPIO39
8NC
9GND
10Uart1_TXGPIO8
11Uart1_RXGPIO9
12NC
13NC
14NC
15GND
16PWR
Serial Port
ItemInformation
1PWR
2Uart0 TX
3Uart0 RX
4GND
GPIO
ItemInformation
GPIO11Control for the switch of SIM cards
Commercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase. Therefore, it is essential to have a robust, secure and high performing WiFi solution that is future-proofed, mobile, and scalable. Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.Skype/EMAIL/Teams:sales@wallystech.comWEB:https://www.wallystech.com/
