国产处理器/操作系统迅为iTOP-2K1000开发板
2022年05月27日 10:09 发布者:就是塔塔
【龙芯LS2K1000】开发环境搭建 P1 开发板环境说明:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=1P2 认识龙芯LS2K1000处理器:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=2
P3 安装虚拟机软件:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=3
P4 虚拟机安装Ubuntu20.4系统:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=4
P5 Ubuntu系统基本操作及设置:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=5
P6 安装VMtools工具:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=6
P7 安装SSH服务:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=7
P8 安装vscode:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=8
P9 安装tftp服务:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=9
P10 安装nfs服务:https://www.bilibili.com/video/BV1VU4y1c7Gc?p=10
【北京迅为】龙芯2K1000系统编译与烧写
P1 龙芯2K1000启动方式:https://www.bilibili.com/video/BV1X3411b7zL?p=1
P2 编译烧写重要性说明:https://www.bilibili.com/video/BV1X3411b7zL?p=2
P3 让龙芯开发板跑起来:https://www.bilibili.com/video/BV1X3411b7zL?p=3
P4 安装pmon编译器并编译pmon源码:https://www.bilibili.com/video/BV1X3411b7zL?p=4
P5 编译不带文件系统的内核镜像:https://www.bilibili.com/video/BV1X3411b7zL?p=5
P6 编带文件系统的内核镜像:https://www.bilibili.com/video/BV1X3411b7zL?p=6
P7 使用Ejtag仿真器烧写pmon:https://www.bilibili.com/video/BV1X3411b7zL?p=7
P8 启动ramdisk镜像:https://www.bilibili.com/video/BV1X3411b7zL?p=8
P9 U盘启动:https://www.bilibili.com/video/BV1X3411b7zL?p=9
P10 通过网络加载系统:https://www.bilibili.com/video/BV1X3411b7zL?p=10
P11 固态硬盘启动:https://www.bilibili.com/video/BV1X3411b7zL?p=11
P12 烧写loongnix系统:https://www.bilibili.com/video/BV1X3411b7zL?p=12
【龙芯LS2K1000】pmon基础知识以及启动流程分析
P1 PMON简介:https://www.bilibili.com/video/BV13M4y1P7H8?p=1
P2 PMON目录结构:https://www.bilibili.com/video/BV13M4y1P7H8?p=2
P3 PMON下常用命令(上):https://www.bilibili.com/video/BV13M4y1P7H8?p=3
P4 PMON下常用命令(下):https://www.bilibili.com/video/BV13M4y1P7H8?p=4
P5 PMON下自定义命令:https://www.bilibili.com/video/BV13M4y1P7H8?p=5
P6 PMON下自定义命令延伸扩展:https://www.bilibili.com/video/BV13M4y1P7H8?p=6
P7 pmon启动流程分析(一):https://www.bilibili.com/video/BV13M4y1P7H8?p=7
P8 pmon启动流程分析(二):https://www.bilibili.com/video/BV13M4y1P7H8?p=8
P9 pmon启动流程分析(三):https://www.bilibili.com/video/BV13M4y1P7H8?p=9
P10 pmon启动流程分析(四):https://www.bilibili.com/video/BV13M4y1P7H8?p=10
P11 pmon启动流程分析(五):https://www.bilibili.com/video/BV13M4y1P7H8?p=11
P12 pmon引导顺序分析:https://www.bilibili.com/video/BV13M4y1P7H8?p=12
P13 pmon构建过程分析:https://www.bilibili.com/video/BV13M4y1P7H8?p=13
P14 pmon下Makefile裁剪:https://www.bilibili.com/video/BV13M4y1P7H8?p=14【龙芯2K1000】pmon BSP移植
P1 移植pmon比移植uboot难吗?https://www.bilibili.com/video/BV1mT4y117eN?p=1
P2 pmon下适配can总线:https://www.bilibili.com/video/BV1mT4y117eN?p=2
P3 pmon下使能屏幕背光和pwm:https://www.bilibili.com/video/BV1mT4y117eN?p=3
P4 pmon下配置7寸RGB屏幕触摸:https://www.bilibili.com/video/BV1mT4y117eN?p=4
P5 pmon下适配以太网(一):https://www.bilibili.com/video/BV1mT4y117eN?p=5
P6 pmon下适配以太网(二):https://www.bilibili.com/video/BV1mT4y117eN?p=6
P7 pmon下适配声卡:https://www.bilibili.com/video/BV1mT4y117eN?p=7
P8 pmon下适配风扇:https://www.bilibili.com/video/BV1mT4y117eN?p=8
P9 pmon下适配sii9022a:https://www.bilibili.com/video/BV1mT4y117eN?p=9
P10 pmon下适配nand flash:https://www.bilibili.com/video/BV1mT4y117eN?p=10迅为龙芯2K1000核心板参数:
尺寸: 65mm*55mm
CPU: GS264双核处理器
主频: 800MHz-1GHz
内存: 2GB/1GB DDR3
NAND容量: 512M
存储: 8MB的存储,用来放BOOT引导程序的
电源管理: 支持ACPI
工作电压: 12V和5V
引角扩展: 引出脚多达232个,1.0间距邮票孔方式,满足用户各类扩展需求
系统支持: Busybox;longnix,buildroot 系统,QT5.12
工作温度: 0℃ ~ +70℃
GPU: 内置GPU,支持动态电源管理
图形编程接口: 支持 OpenGL ES2.0, OpenGL ES 1.1,OpenVG
VPU: 解码支持 H264, H263, JPEG, MPEG-4,VP6.2,DivX5
Camera 1路,兼容ITU-R BT 601/656接口IIS: 1 路
SD/MMC/SDIO: 1路
PCIE: 2 路PCIe 2.1
SATA : 1路
Ethernet: 2 路(10/100/1000M)
UART: 3路全功能串口,最大12路串口
IIC: 1路
SPI: 1路
USB: 3 路,USB Host 2.0,1 路,USB OTG
PWM: 4 路
CAN 2 路
LCD 2 路 RGB888
迅为龙芯2K1000底板参数:
尺寸: 190mm*125mm
POWER: 电直流电源输入接口
SWITCH: 电源开关
Ethernet: 2 路10M/100M/1000M自适应以太网
USB HOST: 4路USB2.0
OTG: 支持
Mini HDMI: 支持
WIFI/BT: 板载WIFI、蓝牙二合一模块
Mini PCIE: 可外接mini PCIE接口的4G模块,具备PCIE2.0单通道
4G模块: 支持(选配)
SIM Card: 1个
UART: 2路串口
RS485: 1路
CAN: 2路
蜂鸣器: 一个有源蜂鸣器
RTC: 支持
LIO/UART: (2mm间距20PIN插座引出)
GPIO: (2mm间距20PIN插座引出)
耳机接口: 标准3.5mm耳机接口
JTAG: 1路JTAG调试接口(2mm间距10PIN插座引出)
GPS: 一路GPS(选配)
固态硬盘接口: 1路(SATA固态盘选配)
按键: 3个
温度传感器: 支持
风扇驱动: 支持
更多内容可以关注:北京迅为
