MS8422N英文规格书CS8422_24bit,192kHz,Asynchronous Sample Rate Converter
2021年04月13日 11:54 发布者:musiccast
PRODUCT DESCRIPTIONMS8422N is a 24 bit, high performance asynchronous sample rate
converter. It integrates digital audio interface receiver. It supports
IEC60958, S/PDIF, EIAJ CP1201 and AES3 interface standards.Audio
data is input by audio interface receiver or three wire serial audio
ports, and output through two three wire serial audio output ports.
QFN32 光纤同轴音频输入151 1247 6010 莫 先 生 2383960712
FEATURES
SPI or I2C software mode and stand-alone hardware mode
All serial audio ports support master or slave mode
Time division multiplexing mode (TDM)
Four general purpose output ports (GPOs)
+3.3V analog supply voltage (VA)
+1.8V-5.0V digital interface voltage (VL)
Complete EIAJ CP1201, IEC-60958, AES3, S/PDIF compatible
28 kHz to 216 kHz sample rate range
2: 1 differential AES3 or 4:1 s / PDIF input multiplexer
Low jitter clock recovery
No external PLL filter is required
Selectable and automatic clock switching
On-chip channel state data buffer
Automatic detection of compressed input audio data stream
Decodes CD Q Sub-Code
140 dB dynamic range
-120 dB THD+N
APPLICATIONS
231524
231523
231525
231530
231527
231526
231529
231528
231524
231523
231525
231530
231527
231526
231529
231528
Digital recording system
Digital mixing console
High performance D/A
Digital audio processor
PRODUCT SPECIFICATION
Part Number Package Marking
MS8422N QFN32 MS8422N
