ARM入门笔记(9)
2010年08月26日 17:31 发布者:绝对好文
第十章 I2C接口实验注:在AT91SAM7Sxx系列中,I2C称作TWI。
一.实验目的
能够正确读写I2C接口芯片存储器(24C02),即写入24C02的数据与读出来的数据相同。
二.实验程序和参数设置
1> 连接器选项设置和启动代码与上一个实验相同
2> I2C驱动程序
ATMEL官方网站上有这方便的参考程序。主要由I2C接口的初始化、I2C的读和写三部分组成。
#i nclude "board.h"
#i nclude "twi.h"
void InitTwi(void)
{ AT91F_TWI_CfgPIO(); //配置TWI的TWD和TWCK管脚 AT91F_PIO_CfgOpendrain(AT91C_BASE_PIOA,(unsigned int)AT91C_PA3_TWD);
AT91F_TWI_CfgPMC (); //使能TWI外围时钟
AT91F_TWI_Configure (AT91C_BASE_TWI); //将TWI设置成主模式
AT91F_SetTwiClock(AT91C_BASE_TWI); //计算、设置时钟发生寄存器
//* \fn AT91F_SetTwiClock
//*计算、设置TWI时钟发生寄存器
void AT91F_SetTwiClock(const AT91PS_TWI pTwi)
{ int sclock;
sclock = (10*MCK /AT91C_TWI_CLOCK);
sclock = (MCK /AT91C_TWI_CLOCK);
if (sclock % 10 >= 5)
sclock = (sclock /10) - 5;
else
sclock = (sclock /10)- 6;
sclock = (sclock + (4 - sclock %4)) >> 2; // div 4
pTwi->TWI_CWGR = 0x00010000 | sclock | (sclock
//* \fn AT91F_TWI_Write
//* \brief Send n bytes to a slave device
int AT91F_TWI_Write(const AT91PS_TWI pTwi ,int address, char *data2send, int size)
{ unsigned int status;
pTwi->TWI_MMR=(AT91C_EEPROM_I2C_ADDRESS| AT91C_TWI_IADRSZ_1_BYTE ) & ~AT91C_TWI_MREAD;
pTwi->TWI_IADR = address; // Set TWI Internal Address Register
status = pTwi->TWI_SR;
pTwi->TWI_THR = *(data2send++);
pTwi->TWI_CR = AT91C_TWI_START;
while (size-- >1){ // Wait THR Holding register to be empty
while (!(pTwi->TWI_SR & AT91C_TWI_TXRDY));
pTwi->TWI_THR = *(data2send++);// Send first byte
pTwi->TWI_CR = AT91C_TWI_STOP;
while (!(pTwi->TWI_SR & AT91C_TWI_TXCOMP)); // Wait transfer is finished
return AT91C_EEPROM_WRITE_OK;
//* \fn AT91F_TWI_Read
//* \brief Read n bytes from a slave device
int AT91F_TWI_Read(const AT91PS_TWI pTwi , int address, char *data2rec, int size)
pTwi->TWI_MMR=(AT91C_EEPROM_I2C_ADDRESS|AT91C_TWI_IADRSZ_1_BYTE) | AT91C_TWI_MREAD; // Set the TWI Master Mode Register
pTwi->TWI_CR = AT91C_TWI_START; // Start transfer
while (size-- >1){ // Wait RHR Holding register is full
while (!(pTwi->TWI_SR & AT91C_TWI_RXRDY));
*(data2rec++) = pTwi->TWI_RHR; // Read byte
*data2rec = pTwi->TWI_RHR; // Read last byte
return AT91C_EEPROM_READ_OK;
3> 主函数
在主函数中,首先调用了TWI的初始化函数,然后进入了超级大循环。在每次写和读时,都对它们的数据缓冲区进行初始化,以查看读、写的正确性。
#i nclude "board.h"
#i nclude "twi.h"
int main ( void )
{ int loop,index=0;
char Wri_data, Red_data; //定义写和读缓冲区
InitTwi(); //TWI初始化
while (1)
{ for (loop = 0; loop 初始化写和读缓冲区的内容
data1 = loop + index;
data2 = 0;
index += 1;
AT91F_TWI_Write(AT91C_BASE_TWI, 0x0, Wri_data, EEP_RW_CHK_CNT);//写
AT91F_TWI_Read(AT91C_BASE_TWI, 0x0, Red_data, EEP_RW_CHK_CNT);//读
}//用单步调试,可比较Wri_data和 Red_data的内容来判断读写是否正确。
三.出现的问题与解决方法
1> 无论写入任何数据,读出来都是同样的数,表明数据没有写入(在调试时对其写操作,器件没有产生应答)。
原因是24C02的写保护管脚没有接地,内部的数据被写保护了。注意:有些厂家的EEROM的该管脚处于悬空时为不保护状态,而有些厂家的EEROM会处于保护状态,因此在用之前一定要仔细阅读厂家的数据手册,或不要将该脚悬空。
2> 对24WC02写的数据和读的数据不一样。
原因是I2C的时钟太快。在本实验程序中,可以减少twi.h中的AT91C_TWI_CLOCK常量的数值。或者直接在程序中修改TWI时钟波形发生寄存器TWI_CWGR。
3> 当写入16字节数据,再读出16字节数据时,最后一个字节总为0。
原因是TWI Master Mode Register的IADRSZ(器件内部地址长度)设成了两个字节(Two-byte),要将改成一个字节(One-byte)。
谢谢
