MLC852芯片解密技术支持
2012年10月15日 15:11 发布者:sm89jm
长期致力于业界疑难芯片/单片机解密技术研究、芯片解密成本降低技术手法研究,依托自身强大的技术研发团队,针对行业疑难项目和重要核心技术开展多项技术攻关。Features
Single chip 8-bit micro-controller
Operating voltage: 2.4V to 5.5V
Memory :
Program ROM: 64 KBytes
Data RAM (stack RAM included) : 3328 Bytes (0000h ~ 0CFFh)
LCD RAM : 144 Bytes
20 input/output pins:
Dedicated I/O pins: P0
Half duplex UART function
Build-in Megawin e-flash interface
Dedicated SPK pin for tone/DAC
LCD driver output:
Max 70 segment ? 16 common
1/16 duty 1/5 bias driving mode
Build-in voltage regulator and pumper to generate LCD voltage for LCD driver
10 level programmable frame rate from 56.7Hz to 113.8Hz
16-level adjustable VLCD from 3.5 V to 5.75 V
One 8-bit resolution DAC output
Programmable sample rate for voice/melody function
Two reloadable 8-bit timers
Two dividers
One 14-bit divider with the clock source from sub-oscillator to generate a 2-Hz interrupt
One 7-bit divider with the clock source from main oscillator
Build-in dual oscillation circuit:
Ring oscillator up to
5MHz at 3.6V – 5.5V
4MHZ at 2.4V – 3.4V
for main oscillator (Fosc)
32768Hz crystal oscillator for sub-oscillator (Fx32)
Build-in 8-level battery-low detector circuit
基于MLC852芯片以上特性,IC解密部能在短时间内完成该芯片的解密服务。诚挚欢迎国内外广大客户就新茂及其它芯片解密事宜来电来访咨询洽谈!本资料 由 www.sm89jiemi.net整理提供,仅供参考。
