Powerint LNK460KG元件最少的T8 20W/85VLED驱动方案
2012年09月24日 12:09 发布者:1770309616
Powerint公司的T8管20 W/85 V LED驱动器是采用LinkSwitchTM-PL系列的 LNK460KG器件,所用元件数量最少,效率大于87%,功率因素大于0.98,A-THD小于10%,输出功率20W,可替代T8管灯.本文介绍了LNK460KG主要特性,框图,典型应用电路,替代A19白炽灯的5W/15V LED驱动器电路图,以及采用LNK460KG的T8 20W/85V LED驱动器主要特性和技术指标,电路图,材料清单和PCB布局图.The LinkSwitch-PL family enables a very small and low cost single-stage power factor corrected constant current driver for solid state lighting. Optimized for direct LED current sensing, the LinkSwitch-PL operates over a wide input voltage range delivering an output power of up to 16 W. The LinkSwitch-PL control algorithm provides flicker-free TRIAC dimming with minimal external components.
Each device incorporates a 725 V rated power MOSFET, a novel discontinuous mode variable frequency variable on-time controller, frequency jitter, cycle by cycle current limit and hysteretic thermal shutdown in a monolithic 4-pin IC, available in SO-8C, eSOP-12, and eDIP-12 packages.
LinkSwitch-PL系列产品亮点:
Dramatically Simplifies Off-line LED Drivers
• Flicker-free phase-controlled TRIAC dimming
• Single stage power factor correction and accurate constant current (CC) output
• Very low component count with small non-electrolytic bulk capacitor for compact replacement lamp designs
• Compact SO8, eSOP, and eDIP packages
• Completely eliminates control loop compensation
Advanced Performance Features
• Optimized for non-isolated flyback designs
• Frequency jitter greatly reduces EMI filter size and costs
• Low dissipation direct sensing of LED current
Advanced Protection and Safety Features
• Cycle skipping regulation for abnormally low output power to clamp peak output current delivered
• 725 V integrated power MOSFET allows small bulk capacitance and maximizes power capability
• Short-circuit, overload, open feedback and output overvoltage protection
• Hysteretic thermal shutdown
• Meets high-voltage creepage between DRAIN and all other pins both on PCB and at package EcoSmart™ - Energy Efficient
• High power factor optimizes system lumen per input VA
• Control algorithm balances switching and conduction losses over line and load to maintain optimum efficiency
图1.LinkSwitch-PL系列框图
图2.LinkSwitch-PL系列典型应用电路图
图2.采用LNK457DG的5W/15V LED驱动器,替代A19白炽灯
采用LNK460KG的T8 20W/85V LED驱动器(DER-345)
The document describes a non-isolated, high efficiency, high power factor (PF) LED driver designed to drive a nominal LED string voltage of 85 V at 235 mA from an input voltage range of 85 VAC to 135 VAC (47 Hz – 63 Hz). The LED driver utilizes the LNK460KG from the LinkSwitch-PL family of ICs.
The topology used is a single-stage non-isolated buck boost that meets the stringent space and efficiency requirements for this design. LinkSwitch-PL based designs provide high power factor (>0.9) meeting international requirements.
This document contains the LED driver specification, schematic, PCB details, bill of materials, transformer documentation and typical performance characteristics.
T8 20W/85V LED驱动器主要特性:
Low cost, low component count (parts), small size (height <8 mm)
PF >0.98, % ATHD <6% at nominal input
Highly energy efficient, >87% at nominal input
Single-stage power factor correction and constant current (CC) output
Integrated protection and reliability features
Output short-circuit and open load protected
Auto recovery thermal shutdown with hysteresis
No damage during brown-out conditions
Meets 1 kV differential line surge
IEC 61000-4-5 ring wave, IEC 61000-3-2 C harmonics and EN55015 B conducted EMI compliant
图3.T8 20W/85V LED驱动器外形图(180 mm x 16.4 mm x 8 mm).
T8 20W/85V LED驱动器主要指标:
图4.T8 20W/85V LED驱动器电路图
T8 20W/85V LED驱动器材料清单:
图5.T8 20W/85V LED驱动器PCB布局图
详情请见:
88847和
88838
来源:网络
