上位机(VB6.0)与下位机(STM32)通过USB接口通讯
2012年08月23日 14:38 发布者:Jewen_he
您好LZ,请问下,我是用VB6.0做上位机,STM32做下位机。通过上位机VB发送一个指令,下位机(STM32)收到后,执行对应的命令,这是怎么实现的,例如STM32点亮8个LED发光二极管!从VB中发送出来地址 &H00,&H01,&H02,&H03,&H04,&H05,&H06,&H07
电平 1 1 1 1 1 1 1 1
对应下位机
灯的状况
LED0 LED1 LED2 LED3 LED4 LED5 LED6 LED7
亮 亮 亮 亮 亮 亮 亮 亮
Jewen_he 2012年08月24日
dddg 发表于 2012-8-23 15:03 static/image/common/back.gif
搞什么? 通信通没通?没通说个P先搞通再说,通了说个p随便怎么定义。
多谢您,上位机的程序是:
Public Const stopX = &H0
Public Const moveX = &H1
Public Const JogPX = &H2
Public Const JogNX = &H3
Public Const PosX = &H4
Public Const stopY = &H10
Public Const moveY = &H11
Public Const JogPY = &H12
Public Const JogNY = &H13
Public Const PosY = &H14
Public Const moveC = &HB0
Public Const moveN = &HB1
Public Const SetPWM = &HC0
Public Const SetIO = &HC1
Public Const SetRERX = &HC2
Public Const SetRERY = &HC3
Public Const SetSonX = &HC4
Public Const SetSonY = &HC5
Public Const RstFLG = &HC6
Public Const SetHdrFlg = &HC7
Public Sub RegSetIO(ByVal port As Byte, ByVal status As Byte)
Dim sbuf(3) As Byte
sbuf(0) = SetIO
sbuf(1) = port
sbuf(2) = status
frmMain.MSComm1.Output = sbuf
End Sub
Private Sub cmdHdrGo_Click()
fraPass.Visible = False
If HeadUp = True Then
HeadUp = False
RegSetIO 9, 0 'A
RegSetIO 10, 0 'B
RegSetIO 11, 0 'C
RegSetIO 12, 0 'D
Else
HeadUp = True
If chkHeaderA.Value Then RegSetIO 9, 1 'A
If chkHeaderB.Value Then RegSetIO 10, 1 'B
If chkHeaderC.Value Then RegSetIO 11, 1 'C
If chkHeaderD.Value Then RegSetIO 12, 1 'D
End If
End Sub
下位机的程序
void Set_IO(unsigned char index,unsigned char sbit)
{ switch(index)
case 1:
GPIO_WriteBit(GPIOA,GPIO_Pin_4,sbit);
break;
case 2:
GPIO_WriteBit(GPIOA,GPIO_Pin_5,sbit);
break;
case 3:
GPIO_WriteBit(GPIOA,GPIO_Pin_6,sbit);
break;
case 4:
GPIO_WriteBit(GPIOA,GPIO_Pin_7,sbit);
break;
case 5:
GPIO_WriteBit(GPIOB,GPIO_Pin_0,sbit);
break;
case 6:
GPIO_WriteBit(GPIOB,GPIO_Pin_1,sbit);
break;
case 7:
GPIO_WriteBit(GPIOB,GPIO_Pin_6,sbit);
break;
case 8:
GPIO_WriteBit(GPIOB,GPIO_Pin_7,sbit);
break;
case 10: case 9:
GPIO_WriteBit(GPIOB,GPIO_Pin_8,sbit);
break;
GPIO_WriteBit(GPIOB,GPIO_Pin_9,sbit);
break;
case 11:
GPIO_WriteBit(GPIOB,GPIO_Pin_10,sbit);
break;
case 12:
GPIO_WriteBit(GPIOB,GPIO_Pin_11,sbit);
break;
case 13:
GPIO_WriteBit(GPIOB,GPIO_Pin_12,sbit);
break;
case 14:
GPIO_WriteBit(GPIOB,GPIO_Pin_13,sbit);
break;
case 15:
GPIO_WriteBit(GPIOB,GPIO_Pin_14,sbit);
break;
case 16:
GPIO_WriteBit(GPIOB,GPIO_Pin_15,sbit);
break;
case 17:
GPIO_WriteBit(GPIOA,GPIO_Pin_8,sbit);
if(sbit) srdX.error_code &=0xBF;
break;
case 18:
GPIO_WriteBit(GPIOA,GPIO_Pin_9,sbit);
if(sbit) srdY.error_code &=0xBF;
break;
比如我现在VB中发送到下位机 执行 RegSetIO 9, 1
然后对应下位机 case 9:
break;
得到PB8端口输出的发光二极管被点亮
反之执行 RegSetIO 9, 0
发光二极管熄灭
我要是把Public Const SetIO = &HC1改成 Public Const SetIO = &HC9或是其他任意值
就得不到上述的结果
这个程序是以前的前辈留下来
我现在的疑问是上位机发送一个指令,在下位机收到后
是怎么执行的(控制发光二极管的亮或灭)
小弟是新手,刚刚接触,搞了好多天,望您指教,多谢多谢!着急啊,闷了好久
多谢您,上位机的程序是:
Dim sbuf(3) As Byte
sbuf(0) = SetIO
sbuf(1) = port
sbuf(2) = status
End Sub
HeadUp = False
RegSetIO 9, 0 'A
RegSetIO 10, 0 'B
RegSetIO 11, 0 'C
RegSetIO 12, 0 'D
Else
HeadUp = True
End If
End Sub
下位机的程序
{ switch(index)
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 10: case 9:
break;
break;
case 11:
break;
case 12:
break;
case 13:
break;
case 14:
break;
case 15:
break;
case 16:
break;
case 17:
break;
case 18:
break;
然后对应下位机 case 9:
break;
得到PB8端口输出的发光二极管被点亮
反之执行 RegSetIO 9, 0
发光二极管熄灭
就得不到上述的结果
这个程序是以前的前辈留下来
是怎么执行的(控制发光二极管的亮或灭)
mxh0506 2012年08月26日
如果你想继续用MSComm控件,又要用USB,考虑在STM32上实现虚拟串口吧。通过USB虚拟出的串口比物理串口快多了。
Jewen_he 2012年08月31日
mxh0506 发表于 2012-8-26 23:36 static/image/common/back.gif
如果你想继续用MSComm控件,又要用USB,考虑在STM32上实现虚拟串口吧。通过USB虚拟出的串口比物理串口快多了 ...
多谢多谢!问题已经解决了,闷了好几天!多谢大家的鼎力相助
fangmengxing 2013年01月11日
edaboy 2013年01月24日
VB不太好弄底层的东东,只好虚拟通用设备了,比如串口,磁盘,HID等
测试直接回帖。
