AKM AK4957 24位立体声CODEC解决方案
2012年08月13日 12:28 发布者:1770309616
AKM公司的AK4957是集成了麦克风,扬声器,视频放大器和LDO的24位立体声CODEC,具有录音功能,播放功能和视频功能,主时钟有PLL和外接时钟两种模式,MIC放大器具有+21dB/+18dB/+16dB/+14dB/+8dB/0dB增益,数字自动音量控制(ALC),模拟电源(AVDD)2.8V-3.6V,数字电源(DVDD)1.6V-2.0V,适合于具有录音/播放功能的手提设备.本文介绍了AK4957主要特性,框图, 立体声和单声道数字MIC连接图,以及评估板AKD4957-B功能,框图,电路图和PCB布局图.The AK4957 is a 24bit stereo CODEC with a microphone, speaker, video amplifiers and LDO. The input circuits include a microphone amplifier and the output circuits include a speaker amplifier. It is suitable for portable application with recording/playback function. A one channel composite In/Out video amplifier is also integrated. The AK4957 is available in a small 32pin QFN (4mm x 4mm, 0.4mm pitch), saving mounting area on the board.
AK4957主要特性:
1. Recording Functions
• Stereo Single-ended input with two Selectors
• MIC Amplifier (+21dB/+18dB/+16dB/+14dB/+8dB/0dB)
• Digital ALC (Automatic Level Control) (Setting Range: +36dB ∼ −54dB, 0.375dB Step)
• ADC Performance: S/(N+D): 83dB, DR, S/N: 88dB (MIC-Amp=+18dB)S/(N+D): 85dB, DR, S/N: 96dB (MIC-Amp=0dB)
• Microphone Sensitivity Compensation
• 5 Band Notch Filter
• Stereo Separation Emphasis Circuit
• Digital MIC Interface 2. Playback Functions
• Soft Mute
• Digital ALC (Automatic Level Control)(Setting Range: +36dB ~ −54dB, 0.375dB Step)
• Digital Volume Control (+12dB ~ −115dB, 0.5dB Step & Mute)
• Stereo Line Output
- Output Voltage: 1Vrms (AVDD= 3.3V)
- S/(N+D): 85dB
- S/N: 92dB
• Mono Mixing Output
• Mono Speaker-Amplifier
- S/(N+D): 65dB@150mW, 60dB@250mW,
- S/N: 90dB
- BTL Output
- Output Power: 400mW@8Ω (AVDD=3.3V)
• Analog Mixing: BEEP Input
3. Master Clock:
(1) PLL Mode
• Frequencies: 11.2896MHz, 12MHz, 13.5MHz, 24MHz, 27MHz (MCKI pin)32fs or 64fs (BICK pin)(2) External Clock Mode
• Frequencies: 256fs, 512fs or 1024fs (MCKI pin)Output Master Clock Frequency: 32fs/64fs/128fs/256fs
4. Sampling Frequencies
• PLL Slave Mode (MCKI pin):8kHz, 11.025kHz, 12kHz, 16kHz, 22.05kHz, 24kHz, 32kHz, 44.1kHz, 48kHz
• PLL Master Mode:8kHz, 11.025kHz, 12kHz, 16kHz, 22.05kHz, 24kHz, 32kHz, 44.1kHz, 48kHz
• EXT Master/Slave Mode:
7.35kHz ~ 48kHz (256fs), 7.35kHz ∼ 48kHz (512fs), 7.35kHz ∼ 13kHz (1024fs)
5. μP I/F: 3-wire Serial, I2C Bus (Ver 1.0, 400kHz Fast-Mode)
6. Master/Slave Mode
7. Audio Interface Format: MSB First, 2’s complement
• ADC: 24bit MSB justified, 16/24bit I2S
• DAC: 24bit MSB justified, 16bit LSB justified, 24bit LSB justified, 24bit I2S
8. Video Functions
• One Composite Signal Input
• Video Amplifier for Composite Signal Output Gain: +6 / +9 / +12 / +16.5dB
• Low Pass Filter
9. Ta = −30 ∼ 85℃
10. Power Supply:
• Analog Power Supply (AVDD): 2.8 ~ 3.6V
• Digital Power Supply (DVDD): 1.6 ~ 2.0V
• Digital I/O Power Supply (TVDD): 1.6 or DVDD – 0.2 ~ 3.6V
Package: 32pin QFN (4.0 x 4.0 mm, 0.4mm pitch)
图1. AK4957框图
图2. AK4957立体声数字MIC连接案例图
图3. AK4957单声道数字MIC连接案例图
图4. AK4957系统连接图
评估板AKD4957-B
The AKD4957-B is an evaluation board for AK4957, 24bit stereo CODEC with a microphone/ speaker/ video amplifiers, and LDO. The AKD4957-B can control various settings using the USB port, can be easily evaluated. Also features a USB Audio device, the audio signal can be input through the USB port from PC. The AKD4957-B has the Digital Audio I/F and can achieve the interface with digital audio systems via optical connector. AKD4957-B is equipped with Line output, Mic input and Headphone output terminals. Has also carried Flash ROM, a stand-alone operation is possible.
评估板AKD4957-B功能:
• DIR/DIT with optical input/output
• With USB-Audio device
• Equipped with three digital audio interface
- Optical Input / Output
- USB Input
- 10-pin header for external interfaces
• USB port for board control
图5.评估板AKD4957-B框图
图6.评估板AKD4957-B电路图(1)
图7.评估板AKD4957-B电路图(2)
图8.评估板AKD4957-B电路图(3)
图9.评估板AKD4957-B电路图(4)
图10.评估板AKD4957-B电路图(5)
图11.评估板AKD4957-B电路图(6)
图12.评估板AKD4957-B布局图(1)
图13.评估板AKD4957-B布局图(2)
图14.评估板AKD4957-B布局图(3)
图15.评估板AKD4957-B布局图(4)
图16.评估板AKD4957-B布局图(5)
图17.评估板AKD4957-B布局图(6)
图18.评估板AKD4957-B布局图(7)
详情请见:
85814和
85815
来源:网络
