Cypress CY7C68053 USB 2.0 MCU开发方案
2012年07月12日 20:15 发布者:1770309616
Cypress公司的MoBL-USB™ FX2LP18 (CY7C68053)是低功耗高度集成的USB 2.0 微控制器(MCU),集成了USB 2.0收发器,串行接口引擎(SIE),增强型8051微控制器和可编程外设接口,超低功耗.数据速率超过53MB/秒,达到USB 2.0带宽最大允许值,主要用在手机,智能手机,PDA,MP3播放器等.本文介绍了CY7C68053主要特性,方框图以及CY3687 MoBL-USB FX2LP18开发板主要特性,电路图,材料清单和PCB布局图.Cypress Semiconductor Corporation’s MoBL-USB™ FX2LP18 (CY7C68053) is a low voltage (1.8 V) version of the EZ-USB® FX2LP (CY7C68013A), which is a highly integrated, low power USB 2.0 microcontroller. By integrating the USB 2.0 transceiver, serial interface engine (SIE), enhanced 8051 microcontroller, and a programmable peripheral interface in a single chip, Cypress has created a very cost effective solution that provides superior time-to-market advantages with low power to enable bus powered applications.
The ingenious architecture of MoBL-USB FX2LP18 results in data transfer rates of over 53 Mbytes per second, the maximum allowable USB 2.0 bandwidth, while still using a low cost 8051 microcontroller in a package as small as a 56VFBGA (5 mm x 5 mm). Because it incorporates the USB 2.0 transceiver, the MoBL-USB FX2LP18 is more economical, providing a smaller footprint solution than USB 2.0 SIE or external transceiver implementations. With MoBL-USB FX2LP18, the Cypress Smart SIE handles most of the USB 1.1 and 2.0 protocol in hardware, freeing the embedded microcontroller for application-specific functions and decreasing development time to ensure USB compatibility.
The General Programmable Interface (GPIF) and Master/Slave Endpoint FIFO (8 or 16-bit data bus) provide an easy and glueless interface to popular interfaces such as ATA, UTOPIA, EPP, PCMCIA, and most DSP/processors.
CY7C68053主要特性:
■ USB 2.0 9 V USB-IF high speed and full speed compliant (TID#40000188)
■ Single-chip integrated USB 2.0 transceiver, smart SIE, and enhanced 8051 microprocessor
■ Ideal for mobile applications (cell phone, smart phones, PDAs, MP3 players)
❐ Ultra low power
❐ Suspend current: 20 μA (typical)
■ Software: 8051 Code runs from:
❐ Internal RAM, which is loaded from EEPROM
■ 16 kBytes of on-chip code/data RAM
■ Four programmable BULK/INTERRUPT/ISOCHRONOUS endpoints
❐ Buffering options: double, triple, and quad
■ Additional Programmable (BULK/INTERRUPT) 64-Byte Endpoint
■ 8 or 16-Bit External Data Interface
■ Smart Media Standard ECC Generation
■ GPIF (General Programmable Interface)
❐ Allows direct connection to most parallel interface
❐ Programmable waveform descriptors and configuration registers to define waveforms
❐ Supports multiple Ready and Control outputs
■ Integrated, Industry Standard Enhanced 8051
❐ 48 MHz, 24 MHz, or 12 MHz CPU operation
❐ Four clocks per instruction cycle
❐ Three counter/timers
❐ Expanded interrupt system
❐ Two data pointers
■ 1.8 V Core Operation
■ 1.8 V to 3.3 V I/O Operation
■ Vectored USB Interrupts and GPIF/FIFO Interrupts
■ Separate Data Buffers for Setup and Data Portions of a CONTROL Transfer
■ Integrated I2C Controller, runs at 100 or 400 kHz
■ Four Integrated FIFOs
❐ Integrated glue logic and FIFOs lower system cost
❐ Automatic conversion to and from 16-bit buses
❐ Master or slave operation
❐ Uses external clock or asynchronous strobes
❐ Easy interface to ASIC and DSP ICs
■ Available in Industrial Temperature Grade
■ Available in one Pb-free Package with up to 24 GPIOs
❐ 56-pin VFBGA (24 GPIOs)
CY7C68053应用:
There are a wide variety of applications for the MoBL-USB FX2LP18. It is used in cell phones, smart phones, PDAs, and MP3 players, to name a few.
图1.CY7C68053方框图
The CY3687 MoBL-USB™ FX2LP18 Development Kit (DVK) is the best starting point for developing a MoBL-USB based product. The DVK includes a development board, code example, a generic device driver, documentation, and assorted tools. This guide provides a general overview and installation help for the DVK. The software installation of the kit includes additional help files and documentation more specific to the various components in the kit.
图2.MoBL-USB FX2LP18开发板外形图
CY3687 MoBL-USB FX2LP18 Development Board Details
MoBL-USB FX2LP18开发板包括:
The following list shows the components supplied in the CY3687 MoBL-USB FX2LP18 Development Kit. They represent most of the development tools required to build a USB system.
硬件:
■ MoBL-USB FX2LP18 development board
■ Prototyping board (‘breadboard’). This board is compatible with the EZ-USB (FX1/FX2LP) developments kits as well.
■ USB cable
■ RS-232 cable
■ Software Installation CD-ROM
■ Quick start Guide Booklet
■ 3 sample MOBL-USB FX2LP18 IC(CY7C68053-56BAXI)
图3.MoBL-USB FX2LP18开发板电路图
MoBL-USB FX2LP18开发板材料清单:
图4.MoBL-USB FX2LP18开发板PCB布局图详情请见:
81945
和
81946
来源:网络
