Linear LTC3787多相单输出升压电源转换方案
2012年06月26日 09:45 发布者:1770309616
Linear公司的LTC3787是高性能多相单输出同步升压电源转换器控制器,能驱动两个N沟功率MOSFET.输入电压4.5V-38V,输出电压高达60V,±1% 1.200V基准电压, 可编程固定频率50kHz到900kHz,静态电流135uA,主要用于工业,汽车,医疗设备和军用.本文介绍了LTC3787主要特性,方框图, 12相工作连接图以及高效2相24V,46V和48V升压转换器电路图, 4相单输出升压转换器电路图,演示板DC1411A主要性能特性,电路图,材料清单和PCB元件布局图.The LTC3787 is a high performance PolyPhase single output synchronous boost converter controller that drives two N-channel power MOSFET stages out-of-phase. Multiphase operation reduces input and output capacitor requirements and allows the use of smaller inductors than the single-phase equivalent. Synchronous rectification increases efficiency, reduces power losses and eases thermal requirements, enabling high power boost applications.
A 4.5V to 38V input supply range encompasses a wide range of system architectures and battery chemistries. When biased from the output of the boost converter or another auxiliary supply, the LTC3787 can operate from an input supply as low as 2.5V after start-up. The operating frequency can be set for a 50kHz to 900kHz range or synchronized to an external clock using the internal PLL.
PolyPhase operation allows the LTC3787 to be configured for 2-, 3-, 4-, 6- and 12-phase operation.
The SS pin ramps the output voltage during start-up. The PLLIN/MODE pin selects Burst Mode. operation, pulseskipping mode or forced continuous mode at light loads.
LTC3787主要特性:
2-Phase Operation Reduces Required Input and Output Capacitance and Power Supply Induced Noise
Synchronous Operation for Highest Efficiency and Reduced Heat Dissipation
Wide VIN Range: 4.5V to 38V (40V Abs Max) and Operates Down to 2.5V After Start-Up
Output Voltage Up to 60V
±1% 1.200V Reference Voltage
RSENSE or Inductor DCR Current Sensing
100% Duty Cycle Capability for Synchronous MOSFET
Low Quiescent Current: 135μA
Phase-Lockable Frequency (75kHz to 850kHz)
Programmable Fixed Frequency (50kHz to 900kHz)
Power Good Output Voltage Monitor
Low Shutdown Current, IQ < 8μA
Internal LDO Powers Gate Drive from VBIAS or EXTVCC
Thermally Enhanced Low Profile 28-Pin 4mmx 5mm
QFN Package and Narrow SSOP Package
LTC3787应用:
Industrial
Automotive
Medical
Military
图1.LTC3787方框图
图2.LTC3787 12相工作连接图
图3.LTC3787高效2相24V升压转换器电路图
图4.LTC3787高效2相48V升压转换器电路图
图5.LTC3787高效2相36V升压转换器电路图
图6.LTC3787高效2相48V升压转换器电路图
图7.LTC3787采用电感DCR电流检测的高效2相24V升压转换器电路图
图8.LTC3787 4相单输出升压转换器电路图
演示板DC1411A主要性能特性:
图9.演示板DC1411A电路图:输入5-24V,输出24V/6A演示板DC1411A材料清单:
QtyReferencePart DescriptionManufacturer / Part #
REQUIRED CIRCUIT COMPONENTS:
3CIN1,COUT5,COUT10CAP., 150uF,35V,EP-capSUNCON, 35HVH150M12COUT1, COUT2, COUT3, COUT4, COUT6, COUT7, COUT8, COUT9, CIN2, CIN3, CIN4, CIN5Cap.,X5R, 22uF 25V, 20%,1812TDK, C4532X5R1E226M1C2,Cap., NPO, 100pF, 25V,10%,0603AVX, 06033A101KAT1C3Cap.,X7R, 15nF, 25V, 10%,0603AVX, 06033C153KAT4C4,C9,C15,C16Cap., X5R, 0.1uF, 25V, 10%, 0603AVX, 06033D104KAT2A3C5,C10,C18Cap., NPO, 1000pF, 25V,10%,0603AVX, 06033A102KAT1C8Cap., X5R, 4.7uF, 25V, 10%,0805TaiyoYuden, TMK212BJ475KG-T2D1,D2DIODE, 30V, SOD323Infineon, BAS140W2L1,L2Inductor, 3.3uHPULSE-PA1494.362NL2Q2,Q8MOSFET,N Chanel,LFPAKRENESAS, RJK0452DPB2Q4,Q6MOSFET,N Chanel,LFPAKRENESAS, RJK0453DPB4RSNS1,RSNS2,RSNS3,RSNS4Res., Chip, 0.008, 1%, 2010VISHAY, WSL20108L000FEA6R2,R3,R5,R7,R15,R18Res., Chip, 0 Ohm, 1%, 0603VISHAY, CRCW06030000Z0EA1R6Res., Chip, 232K, 1%, 0603VISHAY, CRCW0603232KFKED3R8,R9,R34Res., Chip, 12.1K, 1%, 0603VISHAY, CRCW060312K1FKEA4R11,R16,R35,R36Res., Chip, 10K, 1%, 0603VISHAY, CRCW060310KFKEA4R13,R17,R19,R21Res., Chip, 10, 1%, 0603VISHAY, CRCW060310R0FKEA2R26,C17Res., Chip, 100K, 1%, 0603VISHAY, CRCW0603100KFKEA1R32Res., Chip, 2.21, 1%, 0603VISHAY, CRCW06032R21FNEA1R33Res., Chip, 38.3K ,1%, 0603VISHAY, CRCW060338K3FKEA1U1I.C. LTC3787EUFD QFN28 - 4X5Linear Tech.,LTC3787EUFD
ADDITIONAL DEMO BOARD CIRCUIT COMPONENTS:
0C1,C19,C20OPT, 0603
0Q1,Q3,Q5,Q7OPT, LFPAK
0R1,R4,R10,R31OPT, 0603
HARDWARE-FOR DEMO BOARD ONLY:
11E1,E5,E6,E7,E8,E11, E12,E13,E14,E15,E21Turret, Testpoint , 091" Mill Max 2501-2-00-80-00-00-07-02E2,E4JACK BANANAKEYSTONE, 575-42E9,E10STUD, TEST PINPEM KFH-032-104(E9,E10)X2NUT, BRASS NUTS # 10-32ANY #10-322E9,E10RING, LUG RING # 10KEYSTONE #102E9,E10WASHER, TIN PLATED BRASSANY #10 2JP1,JP5Headers, 4 Pins 2mm Ctrs. Samtec TMM-104-02-L-S1JP2Headers, 3 Pins 2mm Ctrs. Samtec TMM-103-02-L-S4XJP1-XJP2Shunt, 2mm Ctrs. Samtec 2SN-BK-G4
STAND-OFF, NYLON 0.5" tall KEYSTONE, 8833(SNAP ON)
图10.演示板DC1411A PCB元件布局图:顶层
图11.演示板DC1411A PCB元件布局图:底层
详情请见:
80216
和
80217
来源:网络
