Altera Stratix V GX FPGA开发方案
2012年05月17日 13:43 发布者:1770309616
Altera公司的Stratix V FPGA包括GT, GX, GS和E四个系列,采用28nm技术,集成了高达28.05Gbps的收发器和独特的硬件IP区块,适合不同的应用如包括PCI Express® (PCIe®)Gen3在内的宽带应用,40G/100G和更高的数据应用,高性能高精度的DSP应用.本文介绍了Stratix V FPGA主要特性,Stratix V GT, GX和GS 器件框图以及Altera® Stratix® V GX FPGA开发套件主要特性和元件区块,框图,Stratix V GX FPGA开发板主要元件表,电路图和材料清单,PCB布局图.Altera’s 28-nm Stratix V FPGAs include innovations such as an enhanced core architecture, integrated transceivers up to 28.05 gigabits per second (Gbps), and a unique array of integrated hard intellectual property (IP) blocks. With these innovations, Stratix V FPGAs deliver a new class of application-targeted devices optimized for:
■ Bandwidth-centric applications and protocols, including PCI Express® (PCIe®)Gen3
■ Data-intensive applications for 40G/100G and beyond
■ High-performance, high-precision digital signal processing (DSP) applications
Stratix V devices are available in four variants (GT, GX, GS, and E), each targeted for a different set of applications. For higher volume production, you can prototype with Stratix V FPGAs and use the low-risk, low-cost path to HardCopy® V ASICs.
Stratix V GT devices, with both 28.05-Gbps and 12.5-Gbps transceivers, are optimized for applications that require ultra-high bandwidth and performance in areas such as 40G/100G/400G optical communications systems and optical test systems. 28.05-Gbps and 12.5-Gbps transceivers are also known as GT and GX channels, respectively.
Stratix V GX devices offer up to 66 integrated 14.1-Gbps transceivers supporting backplanes and optical modules. These devices are optimized for high-performance, high-bandwidth applications such as 40G/100G optical transport, packet processing,and traffic management found in wireline, military communications, and network test equipment markets.
Stratix V GS devices have an abundance of variable precision DSP blocks, supporting up to 3,926 18x18 or 1,963 27x27 multipliers. In addition, Stratix V GS devices offer integrated 14.1-Gbps transceivers, which support backplanes and optical modules.
These devices are optimized for transceiver-based DSP-centric applications found in wireline, military, broadcast, and high-performance computing markets. Stratix V E devices offer the highest logic density within the Stratix V family with nearly one million logic elements (LEs) in the largest device. These devices are optimized for applications such as ASIC and system emulation, diagnostic imaging,
and instrumentation.
Stratix V FPGA主要特性:
■ Technology
■ 28-nm TSMC process technology
■ 0.85-V core voltage
■ Low-power serial transceivers
■ 28.05-Gbps transceivers on Stratix V GT devices
■ Electronic dispersion compensation (EDC) for XFP, SFP+, QSFP, CFP optical module support
■ Adaptive linear and decision feedback equalization
■ 600-Megabits per second (Mbps) to 14.1-Gbps backplane capability
■ Transmit pre-emphasis and de-emphasis
■ Dynamic reconfiguration of individual channels
■ On-chip instrumentation (EyeQ non-intrusive data eye monitoring)
■ General-purpose I/Os (GPIOs)
■ 1.4-Gbps LVDS
■ 1,066-MHz external memory interface
■ On-chip termination (OCT)
■ 1.2-V to 3.3-V interfacing for all Stratix V devices
■ Embedded HardCopy Block
■ PCIe Gen3, Gen2, and Gen1 complete protocol stack, x1/x2/x4/x8 end point and root port
■ Embedded transceiver hard IP
■ Interlaken physical coding sublayer (PCS)
■ Gigabit Ethernet (GbE) and XAUI PCS
■ 10G Ethernet PCS
■ Serial RapidIO® (SRIO) PCS
■ Common Public Radio Interface (CPRI) PCS
■ Gigabit Passive Optical Networking (GPON) PCS
■ Power Management
■ Programmable Power Technology
■ Quartus II integrated PowerPlay Power Analysis
■ High-performance core fabric
■ Enhanced ALM with four registers
■ Improved routing architecture reduces congestion and improves compile times
■ Embedded memory blocks
■ M20K: 20-Kbit with hard error correction code (ECC)
■ MLAB: 640-bit
■ Variable precision DSP blocks
■ Up to 500 MHz performance
■ Natively support signal processing with precision ranging from 9x9 up to 54x54
■ New native 27x27 multiply mode
■ 64-bit accumulator and cascade for systolic finite impulse responses (FIRs)
■ Embedded internal coefficient memory
■ Pre-adder/subtractor improves efficiency
■ Increased number of outputs allows more independent multipliers
■ Fractional PLLs
■ Fractional mode with third-order delta-sigma modulation
■ Integer mode
■ Precision clock synthesis, clock delay compensation, and zero delay buffer (ZDB)
■ Clock networks
■ 717-MHz fabric clocking
■ Global, quadrant, and peripheral clock networks
■ Unused clock networks can be powered down to reduce dynamic power
■ Device Configuration
■ Serial and parallel flash interface
■ Enhanced advanced encryption standard (AES) design security features
■ Tamper protection
■ Partial and dynamic reconfiguration
■ Configuration via Protocol (CvP)
■ High-performance packaging
■ Multiple device densities with identical package footprints enables seamless migration between different FPGA densities
■ FBGA packaging with on-package decoupling capacitors
■ Lead and RoHS-compliant lead-free options
■ HardCopy V migration
图1.Stratix V GT, GX和GS 器件框图
The Altera® Stratix® V GX FPGA Development Kit is a complete design environment
that includes both the hardware and software you need to develop Stratix V GX FPGA designs. The following list describes what you can accomplish with the kit:
■ Test signal quality of the FPGA transceiver I/Os (up to 12.5 Gbps).
■ Develop and test PCI Express® (PCIe) 2.0 designs.
■ Develop and test memory subsystems consisting of SyncFlash, DDR3, and QDRII+.
■ Develop and test SDI with the embedded 75-ohm 3G SDI transceivers.
■ Develop embedded designs utilizing the Nios® II processor and external memory.
■ Develop and test network designs utilizing Triple Speed Ethernet MegaCore® and external RJ-45 jack.
■ Develop and test optical networking designs using the 10G and 40G Ethernet MAC MegaCores and the QSFP Optical Interface.
■ Take advantage of the modular and scalable design by using the high-speed mezzanine card (HSMC) connectors to interface to over 40 different HSMCs provided by Altera partners, supporting protocols such as Serial RapidIO®, 10 Gigabit Ethernet, SONET, Common Public Radio Interface (CPRI), Open Base Station Architecture Initiative (OBSAI) and others.
■ Measure the FPGA’s power consumption.
■ Control twelve different programmable clock oscillators using the Clock Control GUI.The Stratix V GX FPGA Development Kit includes the following hardware:
■ Stratix V GX FPGA development board—A development platform that allows you to develop and prototype hardware designs running on the Stratix V GX FPGA.
■ HSMC loopback board—A daughtercard that allows for loopback testing all signals on the HSMC interface using the Board Test System.
■ Power supply and cables—The kit includes the following items:
■ Power supply and AC adapters for North America/Japan, Europe, and the United Kingdom
■ Standard USB A to micro-USB cable
■ Ethernet cable
■ 75 Ω SMB video cable
软件包括:
The Quartus II Development Kit Edition (DKE) software includes the following items:
■ Quartus II Software—The Quartus II software, including the Qsys system integration tool, provides a comprehensive environment for network on a chip (NoC) design. The Quartus II software integrates into nearly any design environment and provides interfaces to industry-standard EDA tools.
■ MegaCore® IP Library—A library that contains Altera IP MegaCore functions. You can evaluate MegaCore functions by using the OpenCore Plus feature to do the following:
■ Simulate behavior of a MegaCore function within your system.
■ Verify functionality of your design, and quickly and easily evaluate its size and speed.
■ Generate time-limited device programming files for designs that include MegaCore functions.
■ Program a device and verify your design in hardware
Altera® Stratix® V GX FPGA开发板包括以下主要的元件区块:
■ Altera Stratix V FPGA (5SGXEA7K2F40C2) in the 1517-pin FineLine BGA Package
■ 622,000 Les
■ 358,500 adaptive logic modules (ALMs)
■ 50-Mbits embedded memory
■ 36 transceivers (12.5 Gbps)
■ 174 full-duplex LVDS channels
■ 28 phase locked loops (PLLs)
■ 512 18x18-bit multipliers
■ 850-mV core voltage
■ 696 user I/Os
■ 2 PCI Express hard IP blocks
■ MAX® V CPLD (5M2210ZF256C4) System Controller in the 256-pin FineLine BGA Package
■ 2,210 Les
■ 203 user I/Os
■ 1.8-V core voltage
■ FPGA Configuration Circuitry
■ MAX II CPLD (EPM570GM100) and Flash Fast Passive Parallel (FPP) configuration
■ On-Board USB-BlasterTM II for use with the Quartus® II Programmer, Nios® II Software Build Tools, and System Console.
■ On-Board Clocking Circuitry
■ 50-MHz, 100-MHz, 125-MHz, and programmable oscillators
■ SMA connector for clock input (LVPECL)
■ Memory devices
■ 1152-Mbyte DDR3 SDRAM with a 72-bit data bus
■ 4.5-Mbyte QDRII+ SRAM with a 18-bit data bus (footprint is compatible for 9-Mbyte QDRII with a 18-bit data bus)
■ Two 512-Mbyte synchronous flash with a 16-bit data bus
■ Communication Ports
■ PCI Express (PCIe) x8 edge connector
■ Two HSMC ports
■ One universal HSMC port A
■ One DQS-type HSMC port B
■ SMB for SDI input and output
■ QSFP
■ USB 2.0
■ Gigabit Ethernet
■ LCD header
■ General User I/O
■ 16 user LEDs
■ Two-line character LCD display
■ Six configuration status LEDs
■ Five PCI Express LEDs
■ Four Ethernet LEDs
■ Push Button and DIP Switches
■ One CPU reset push button
■ Three general user push buttons
■ Two configuration push buttons
■ Eight user DIP switches
■ Four MAX V control DIP switches
■ Power
■ 19-V (laptop) DC input
■ PCI Express edge connector power
■ On-Board power measurement circuitry
■ System Monitoring
■ Power—voltage, current, wattage
■ Temperature—FPGA die, local board
■ Mechanical
■ PCI Express short form factor
■ PCI Express chassis or bench-top operation
图2.Stratix V GX FPGA开发板框图
图3.Stratix V GX FPGA开发板外形和特性图
Stratix V GX FPGA开发板主要元件表:
图4.Stratix V GX FPGA开发板电路图(1)
更详细的Stratix V GX FPGA开发板电路图详见:
76763Stratix V GX FPGA开发板材料清单见:
图5.Stratix V GX FPGA开发板PCB元件布局图:正面
图6.Stratix V GX FPGA开发板PCB元件布局图:背面
76762详情请见:
76761和
76782
76788
76794
76795
76799
76800
76801
76802
来源:网络
这么好的资料,我竟然是第一个下!
