Renesas RX210系列32位MCU开发方案
2012年03月16日 19:39 发布者:1770309616
Renesas公司的RX210系列是高性能低电压超低功耗基于32位RX CPU核的闪存MCU,CPU具有73基本指令和9个DSP指令,最大工作频率50MHz,78DMIPS性能,乘法和除法单元能处理32x32位的运算,具有快速中断和5级流水线的CISC哈佛架构,片内调试电路,主要用在超低功耗的嵌入式应用.本文介绍了RX210系列主要特性,方框图以及Renesas入门套件(RSK)主要特性,RSK板布局图,方框图和电路图.The RX210 Group is an MCU with the high-speed, high-performance RX CPU as its core. A variable-length instruction format has been adopted for the RX CPU. Allocating the more frequently used instructions to the shorter instruction lengths facilitates the development of efficient programs that take up less memory.
The CPU has 73 basic instructions and and nine DSP instructions, for a total of 82 instructions. It has 10 addressing modes and caters to register–register operations, register–memory operations, immediate–register operations, immediate–memory operations, memory–memory transfer, and bitwise operations. High-speed operation was realized by achieving execution in a single cycle not only for register–register operations, but also for other types of multiple instructions. The CPU includes an internal multiplier and an internal divider for high-speed multiplication and division.
The RX CPU has a five-stage pipeline for processing instructions. The stages are instruction fetching, instruction decoding, execution, memory access, and write-back. In cases where pipeline processing is drawn-out by memory access, subsequent operations may in fact be executed earlier. By adopting “out-of-order completion” of this kind, the execution of instructions is controlled to optimize numbers of clock cycles.
RX210主要特性:
■ 32-bit RX CPU core
Max. operating frequency: 50 MHz
Capable of 78 DMIPS in operation at 50 MHz
Accumulator handles 64-bit results (for a single instruction) from 32- × 32-bit operations
Multiplication and division unit handles 32- × 32-bit operations (multiplication instructions take one CPU clock cycle)
Fast interrupt
CISC Harvard architecture with 5-stage pipeline
Variable-length instructions, ultra-compact code
On-chip debugging circuit
■ Low-power design and architecture
Operation from a single 1.62- to 5.5-V supply
1.62-V operation available (at up to 20 MHz)
Deep software standby mode with RTC remaining usable
Four low-power modes
■ On-chip flash memory for code, no wait states
50-MHz operation, 20-ns read cycle
No wait states for reading at full CPU speed
128- to 512-Kbyte capacities
User code programmable via the SCI
Programmable at 1.62 V
For instructions and operands
■ On-chip data flash memory
Eight Kbytes
Erasing and programming impose no load on the CPU.
■ On-chip SRAM, no wait states
20- to 64-Kbyte size capacities
■ DMA
DMACA: Incorporates four channels
DTC: Four transfer modes
■ ELC
Module operation can be initiated by event signals without going through interrupts.
Modules can operate while the CPU is sleeping.
■ Reset and supply management
Nine types of reset, including the power-on reset (POR)
Low voltage detection (LVD) with voltage settings
■ Clock functions
Frequency of external clock: Up to 20 MHz
Frequency of the oscillator for sub-clock generation: 32.768 kHz
PLL circuit input: 4 to 12.5 MHz
On-chip low- and high-speed oscillators, dedicated onchip low-speed oscillator for the IWDT
Generation of a dedicated 32.768-kHz clock for the RTC
Clock frequency accuracy measurement circuit (CAC)
■ Real-time clock
Adjustment functions (30 seconds, leap year, and error)
Time capture function
Time capture on event-signal input through external pins
RTC capable of initiating return from deep software standby mode
■ Independent watchdog timer
125-kHz on-chip low-speed oscillator produces a dedicated clock signal to drive IWDT operation.
■ Useful functions for IEC60730 compliance
Self-diagnostic and disconnection-detection functions for the AD converter, clock-frequency accuracymeasurement circuit, independent watchdog timer, functions to assist in RAM testing, etc.
■ Up to nine communications interfaces
SCI with many useful functions (up to seven interfaces)
Asynchronous mode, clock synchronous mode, smart card interface
I2C bus interface: Transfer at up to 1 Mbps, capable of SMBus operation (1 interface)RSPI (1)
■ External address space
Four CS areas (4 × 16 Mbytes)
8- or 16-bit bus space is selectable per area
■ Up to 14 extended-function timers
16-bit MTU2: input capture, output capture, complementary PWM output, phase counting mode (6 channels)
8-bit TMR (4 channels)
16-bit compare-match timers (4 channels)
■ 12-bit A/D converter
Capable of conversion within 1 μs
Sample-and-hold circuits (for three channels)
Three-channel synchronized sampling available
Self-diagnostic function and analog input disconnection detection assistance function
■ 10-bit D/A converter
■ Analog comparator
■ Programmable I/O ports
5-V tolerant, open drain, input pull-up, switching of driving ability
■ MPC
Multiple locations are selectable for I/O pins of peripheral functions
■ Temperature sensor
■ Operating temp. range
-40 degreeC to +85 degree C
图1.RX210方框图
RX210 系列Renesas入门套件
The Renesas Starter Kit for RX210 is intended as a user-friendly introductory and evaluation tool for the RX210 microcontroller. The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E1 emulator and/or Flash Development Toolkit.
The Renesas Starter Kit for RX210 may be connected to the host PC using a simple RS232 serial connection or via the included USB E1 on chip debugging interface.
The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools.
图2.RX210 系列入门套件外形图
RX210 系列Renesas入门套件(RSK)主要特性:
This RSK provides an evaluation of the following features:
• Renesas microcontroller programming
• User code debugging
• User circuitry such as switches, LEDs and a potentiometer
• Sample application
• Sample peripheral device initialisation code
The RSK board contains all the circuitry required for microcontroller operation.
图3.RX210 系列RSK板布局图
图4.RX210 系列RSK板顶层元件布局图
图5.RX210 系列RSK板方框图
图6.RX210 系列RSK板电路图(1)
图7.RX210 系列RSK板电路图(2)
图8.RX210 系列RSK板电路图(3)
图9.RX210 系列RSK板电路图(4)
图10.RX210 系列RSK板电路图(5)
详情请见:
69733和
69734以及
69735
