AKM AK7782双路音频信号处理解决方案
2012年03月13日 11:39 发布者:1770309616
AKM 公司的AK7782是集成24位5路ADC和SRC的双路音频信号处理器(DSP),同时还集成了8:2立体声输入选择器,取样速率转换器,速率高达96kHz,ADC取样频率从7.35kHz 到96kHz.本文介绍了AK7782主要特性,方框图,DSP方框图,AK7782评估板AKD7782-A主要功能,方框图,电路图以及元件布局图.The AK7782 is an audio digital signal processor with integrated 24bit 5ch ADCs, an 8:2 stereo input selector and sample rate converters that support 2ch inputs and the frequency up to 96kHz. The ADC supports wide range of sampling frequency from 7.35kHz to 96kHz. Two integrated audio DSPs have high performance processing speed of 2560step/fs (at 48kHz sampling), and two 6k-word delay RAMs allow surround processing, time alignment adjusting and FIR filtering. As the AK7782 is a RAM based DSP, it is programmable for various user requirements. It is housed in a 100pin LQFP package.
AK7782主要特性:
□ Word Length: 28-bits
□ Instruction Cycle Time: 8.1ns (2560fs, fs=48kHz)
□ Processing Step: 2560 steps (max) /fs= 48kHz, 44.1kHz (Normal Speed)
15360 steps (max) /fs= 8kHz, 7.35kHz
1280 steps (max) fs= 96kHz, 88.2kHz (Double Speed)
□ Multiplier: 24 x 16 → 40-bits (double precision available)
□ Divider: 24 ÷ 24 → 24-bits (floating point normalization function)
□ ALU: 44-bit arithmetic operation (with 4-bit overflow margin)
24-bit arithmetic and logic operation
□ Data Shift: Right shift after multiplication 1, 2, 4, 5, 8, 14, 15-bits
Right shift BUS 1, 2, 3, 4, 8, 14, 15-bits
Left shift after multiplication 1, 2, 3, 4, 8, 15-bits
Left shift BUS 1, 2, 3, 4, 6, 8, 15-bits
Indirect shifting function
□ Program RAM (PRAM): 2048word x 36-bits
□ Coefficient RAM (CRAM): 2048word x 16-bits
□ Data RAM (DRAM): 2048word x 28-bits
□ Offset Register (OFREG): 64word x 13-bits
□ Delay RAM (DLRAM): 168kbit (four types)
● 6kword 28-bits
● 4kword 28-bits + 4kword 14-bits
● 3kword 28-bits + 6kword 14-bits
● 3kword 28-bits + 3kword 28-bits (Linear)
□ Register: 44-bits x 4 (ACC)
28-bits x 12 (TMP)
28-bits x 6 steps stack (PTMP)
□ 24-bit 2ch x 2
□ S/(N+D): 90dB (fs=48kHz)
□ D-range: 96dBA (fs=48kHz)
□ S/N: 96dBA (fs=48kHz)
□ 8ch bidirectional analog input selector
□ High-pass filter (HPF) for DC offset cancellation
□ fs=7.35kHz ~ 96kHz
□ 24bit 1ch
□ S/(N+D) 88dB (fs=48kHz)
□ D-range 95dBA (fs=48kHz)
□ S/N 95dBA (fs=48kHz)
□ Digital volume control
□ Serial Data Input: 14ch (including ADC block)
□ Serial Data Output: 16ch (each DSP outputs are 14ch)
□ Microcomputer Interface: 1ch In/Out or I2C-bus
□ 2ch x 2
□ PLL
□ 3.3V±0.3V, 1.8V ±0.1V
□ Operational Temperature: -40℃ ~ 85℃
□ 100pin LQFP
图1.AK7782方框
图2.AK7782 DSP方框图 ( DSP1 和DSP2)
AK7782评估板AKD7782-A
The AKD7782-A is an evaluation board for AK7782, which is a highly integrated audio processor including 5ch 24bit ADC, 4ch SRC and two audio DSP cores. This board is composed of a main board and a sub board. It is possible to control the setting of board via USB port. RCA connectors are used for the input and output of analog signal. This board also has digital interface and can achieve the interface with digital audio system via optical connector.
评估板AKD7782-A功能:
􀂆 Read/Write access to PRAM, CRAM, OFREG and control registers of AK7782
􀂆 Compatible with 2 types of digital audio interface
- Optical input (x1) / Optical output (x1)
- 10pin header for interface with external data source (x2)
􀂆 ADC1/ADC2 18ch input, ADCM 1ch input, DAC 8ch output(Note: There is no DAC within AK7782. 8ch DAC AK4359 is equipped.)
􀂆 USB port for board control
图3.AKD7782-A 方框图
图4.AKD7782-A 评估板方框图
图5.AKD7782-A 评估板电路图(1)
图6.AKD7782-A 评估板电路图(2)
图7.AKD7782-A 评估板电路图(3)
图8.AKD7782-A 评估板电路图(4)
图9.AKD7782-A 评估板电路图(5)
图10.AKD7782-A 评估板电路图(6)
图11.AKD7782-A 评估板电路图(7)
图12.AKD7782-A 评估板电路图(8)
图13.AKD7782-A 评估板电路图(9)
图14.AKD7782-A 评估板电路图(10)
图15.AKD7782-A 评估板元件布局图
详情请见:
69047和
69048
来源:网络
谢谢分享
