Cirrus CS47048音频系统级芯片(ASOC)评估方案
2012年02月16日 14:10 发布者:1770309616
Cirrus公司的CS470xx系列是新一代音频系统级芯片(ASOC)32位处理器,每秒的乘法运算(MAC/S)为300,000,000,目标应用在高保真对成本敏感的设计.该系列集成了S/PDIF Rx, S/ PDIF Tx,模拟输入,模拟输出和取样速率转换器(SRC),能简化系统设计和降低系统总成本.主要应用在汽车音响,DTV,MP3坞站,AVR和DVD Rx, DSP控制的扬声器(条形音箱,低音扩音箱).本文介绍了CS470xx系列主要特性, CS47048方框图, CDB47xxxD主板和子板方框图以及详细电路图.The CS470xx family is a new generation of audio system-on-a-chip (ASOC) processors targeted at high fidelity, cost sensitive designs. The CS470xx simplifies system design and reduces total system cost by integrating the S/PDIF Rx, S/ PDIF Tx, analog inputs, analog outputs, and sample rate converters (SRCs). For example, a hardware SRC can
down-sample a 192 kHz S/PDIF stream to a lower Fs to reduce memory and MIPS requirements for processing. This integration effectively reduces the chip count from 3 to 1, which allows smaller, less expensive board designs.
The CS470xx is programmed using the simple yet powerful Cirrus proprietary DSP Composer™ GUI development and pre-production tuning tool. Processing chains can be designed using a drag-and-drop interface to utilize functional macro audio DSP primitives and custom audio filtering blocks. The end result is a software image that is downloaded to the DSP via the serial control port.
The Cirrus Framework™ programming environment offers Assembly and C language compilers and other software development tools for porting existing code to the CS470xx family platform.
The CS470xx is available in a 100-pin LQFP package with exposed pad for better thermal characteristics. Both Commercial (0℃ to +70℃) and Automotive (–40℃ to +85℃) temperature grades are available.
CS470xx系列主要特性:
Cost-effective, High-performance 32-bit DSP
300,000,000 MAC/S (multiply accumulates per second)
Dual MAC cycles per clock
72-bit accumulators are the highest precision in the industry
32K x 32-bit SRAM with three 2K blocks assignable to either Y data or program memory
Integrated DAC and ADC Functionality
8 Channels of DAC output: 108dB DR, –98 dB THD+N
4 Channels of ADC input: 105dB DR, –98 dB THD+N
Integrated 5:1 analog mux feeds one stereo ADC
Configurable Serial Audio Inputs and Outputs
Integrated 192 kHz S/PDIF Rx
Integrated 192 kHz S/PDIF Tx
Supports 32-bit serial data @ 192 kHz
Supports 32-bit audio sample I/O between DSP chips
TDM I/O modes
Supports Different Sample Rates (Fs)
Three integrated hardware SRC blocks
Output can be master or slave
Supports dual-domain Fs on S/PDIF vs. I²S inputs
DSP Tool Set with Private Keys Protect Customer IP
Integrated Clock Manager/PLL
Flexibility to operate from internal PLL, external crystal, external oscillator
Input Fs Auto Detection with μC Acknowledgement
Host Control and Boot via I²C™ or SPI™ Serial Interface
Configurable GPIOs and External Interrupt Input
1.8V Core and a 3.3V I/O that is tolerant to 5V input
Low-power Mode
CS470xx系列目标应用:
Automotive head units and outboard amplifiers
Automotive processors and automotive integration hubs
Digital TV
MP3 docking stations
AVR and DVD Rx
DSP controlled speakers (subwoofers, sound bars)
图1.CS47048方框图
图2.CDB47xxxD-DCxx开发板外形图
图3.CDB47xxxD主板方框图
图4.CDB47xxx-DC48子板方框图
图5.CDB47xxD差分板方框图
图6.CDB47xxD(差分)子板连接器
图7.CDB47xxD(差分)数字音频控制连接器
图8.CDB47xxD(差分)数字串行闪存
图9.CDB47xxD(差分)麦克风前置放大器
图10.CDB47xxD(差分)电源连接器
图11.CDB47xxD(差分)ADC滤波器
图12.CDB47xxD(差分)电压输出电路
图13.CDB47xxD(差分)MCU卡接口
图14.CDB47xxD(差分)MCU卡电路
图15.CDB47xxD(差分)MCU卡用户接口
图16. CDB47xxx-DC48子板框图
图17. CDB47xxx-DC48子板电路图
详情请见:
65703和
65705
来源:网络
