三伍微电子 IoT FEM:GSR2501 WIFI标准 BT 功率20 dBm
2024年05月10日 16:00 发布者:Penny2023
Product DescriptionThe GSR2501 is a high performance, fully integrated RFfront end module (FEM) designed for Bluetooth(including EDR), Zigbee applications. The deviceprovides all the functionality of a fully matched poweramplifier (PA), low-noise amplifier (LNA), and twosingle-pole, triple-throw (SP3T) switches.The GSR2501 provides a complete 2.4 GHz WLAN RFsolution from the output of the transceiver to the antenna,and from the antenna to the input of the transceiver. TheLNA increases the receive sensitivity of embeddedsolutions to improve range. The low insertion loss andlow current bypass mode decrease the power consumptionwhen working in a good signal environment. TheGSR2501 also includes digital enable control pins forpower ramp on/off control.The RF blocks operate over a wide supply voltage rangefrom 3.0 V to 5.2 V that allows the GSR2501 to be usedin lithium battery powered applications.The device is provided in a compact, 16-pin 2.3 x 2.3 mmQuad Flat No-Lead (QFN) package. Pin map is shown inFigure 1. A functional block diagram is shown in Figure2.Key Featuresl Saturated output power: 22.5 dBm@3.3 Vl EDR power up to 14 dBml Integrated LNA (1.5 dB noise figure)l Low Insertion Loss Bypass Model Single ended transmit/receive interfacel Input and output matched to 50 ohml Wide supply range ( 3.0 V to 5.2 V)l No external bias resistor is requiredl High Impedance Control PinApplicationsl Range extenderl Wireless sound and audio systemsl Custom 2.4 GHz radio systemsl Wireless sensor networksl Zigbee smart powerl Zigbee extended range devices
