三伍微SOI开关:GSR1303S 频段2.4G 兼容替代RTC6603
2024年04月11日 10:22 发布者:Penny2023
三伍微SOI开关:GSR1303S 频段2.4G 兼容替代RTC6603GSR1303S: CMOS SOI SPDT Switch0.1 – 3.0 GHzApplicationsl WLAN 802.11a/b/g/n/ac/ax networksl ISM band radiosl Low power T/R systemsFeatureslP0.1dB +32dBm typical @ +3.3Vl Low insertion loss (0.4dB @ 2.5GHz)l High isolation (24dB @ 2.5GHz)l Low DC power consumptionl SC-70 6 lead Package (MSL1, 260°C per JEDEC-J-STD-020)l ESD: 1.5 kV HBM on all pinsDescriptionThe GSR1303S is a CMOS SOI single pole dual throw (SPDT) high power switch in a low cost miniature SC-70 6 lead package. The GSR1303S is ideally suited for applications where high power, low insertion loss, and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 3 GHz requiring high power at low control voltage.
