Avnet ADI BF518F FMC CPU评估开发方案
2012年01月17日 22:04 发布者:1770309616
Avnet公司的BF518F FMC CPU开发套件采用ADI Blackfin系列处理器BF518F,能设计和验证Blackfin BF51xF系列DSP处理器,具有标准的外设,能使用户扩展个性化的原型.主要用于工业控制,工厂自动化,智能能量管理,网络功能仪表和测试测量设备.本文介绍了BF51xF系列处理器主要特性,方框图和Blackfin处理器核框图,以及BF518F FMC CPU评估套件主要特性,方框图,电路图和材料清单.Analog Devices BF518F FMC Development Kit
The ADSP-BF512/ADSP-BF512F, ADSP-BF514/ADSPBF514F, ADSP-BF516/ADSP-BF516F, ADSP-BF518/ADSPBF518F processors are members of the Blackfin® family of products, incorporating the Analog Devices/Intel Micro Signal Architecture (MSA). Blackfin processors combine a dual-MAC state-of-the-art signal processing engine, the advantages of a clean, orthogonal RISC-like microprocessor instruction set, and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture.
The processors are completely code compatible with other Blackfin processors.
BF51xF主要特性:
Up to 400MHz high performance Blackfin processor
Two 16-bit MACs, two 40-bit ALUs, four 8-bit video ALUs, 40-bit shifter
RISC-like register and instruction model for ease of
programming and compiler-friendly support
Advanced debug, trace, and performance monitoring
Wide range of operating voltages
Qualified for Automotive Applications
168-ball CSP_BGA or 176-lead LQFP with exposed pad MEMORY
116K bytes of on-chip memory
External memory controller with glueless support for SDRAM and asynchronous 8-bit and 16-bit memories
Optional 4M bit SPI flash with boot option
Flexible booting options from internal SPI flash, OTP memory, external SPI/parallel memories, or from SPI/UART host devices
Code security with Lockbox secure technology
One-time-programmable (OTP) memory
Memory management unit providing memory protection
PERIPHERALS
IEEE 802.3-compliant 10/100 Ethernet MAC with IEEE 1588 support (ADSP-BF518/ADSP-BF518F only)
Parallel peripheral interface (PPI), supporting ITU-R 656 video data formats
2 dual-channel, full-duplex synchronous serial ports (SPORTs), supporting 8 stereo I2S channels
12 peripheral DMAs, 2 mastered by the Ethernet MAC
2 memory-to-memory DMAs with external request lines
Event handler with 56 interrupt inputs
2 serial peripheral interfaces (SPI)
Removable storage interface (RSI) controller for MMC, SD, SDIO, and CE-ATA 2 UARTs with IrDA support
2-wire interface (TWI) controller
Eight 32-bit timers/counters with PWM support
3-phase 16-bit center-based PWM unit
32-bit general-purpose counter
Real-time clock (RTC) and watchdog timer
32-bit core timer
40 general-purpose I/Os (GPIOs)
Debug/JTAG interface
On-chip PLL capable of frequency multiplication
图1.BF51xF方框图
图2.BF51xF Blackfin处理器核框图
BF518F FMC CPU Evaluation Kit provides a complete development platform for designing and verifying applications based on the Analog Devices Blackfin BF51xF family of DSP processors. The kit enables designers to use the BF518F controller with on board standard peripherals and expand their prototype system by enabling customization through the FMC LPC expansion slot.
The Analog Devices BF518F FMC Development Kit, designed by and available exclusively from Avnet Electronics Marketing, provides a simple-to-use platform for hardware and software engineers designing with the Analog Devices BF518F low-power Blackfin® processor and the Microsoft .NET Micro Framework.
The board can operate either as a standalone, or as an FMC Mezzanine Module connected to any VITA 57.1-compliant carrier board. By providing a convenient development platform for applications that combine FPGAs and embedded processors with advanced networking capability, it has never been easier to include signal processing in your next design.
主要应用:
Industrial automation HM
Smart energy management
Network-enabled instrumentation
Test and measurement
图3.BF518F FMC CPU评估板外形图
BF518F FMC CPU评估板主要特性:
• Analog Devices ADSP-BF592 Blackfin processor
• Core performance up to 400 MHz
• 64-lead LFCSP
• Programmable VDDINT core power
• Analog Devices AD5258 TWI digital potentiometer
• Analog Devices ADP1715 low dropout linear regulator
• SPI external flash memory
• Numonyx M25P16 – 16 Mb
• Audio codec
• Analog Devices SSM2603 stereo, 24-bit analog-to-digital and digital-to-analog converters
• Highly efficient headphone amplifier
• Stereo line input and monaural microphone input
• Universal asynchronous receiver/transmitter (UART)
• ADM3202 RS-232 line driver/receiver
• DB9 female connector
• LEDs
• Eight LEDs: one board reset (red), three general-purpose (amber), one power (green), one battery good indicator (green), one battery low indicator (amber) and one battery charging indicator (amber)
• Push buttons
• Four push buttons: one reset, two programmable flags, and one wake-up with debounce logic
• Expansion interface II
• Next generation of the expansion interface design, provides access to most of the processor signals
• Land grid array
• Easy probing of all port pins
• Other features
• JTAG ICE 14-pin header
• Battery charger for a 3.7V single sell Li-Ion battery
图4. EZ-KIT Lite方框图
图5.BF518F FMC CPU评估板电路图(1)
图6.BF518F FMC CPU评估板电路图(2)
图7.BF518F FMC CPU评估板电路图(3)
图8.BF518F FMC CPU评估板电路图(4)
图9.BF518F FMC CPU评估板电路图(5)
图10.BF518F FMC CPU评估板电路图(6)
图11.BF518F FMC CPU评估板电路图(7)
图12.BF518F FMC CPU评估板电路图(8)
图13.BF518F FMC CPU评估板电路图(9)
BF518F FMC CPU评估板材料清单:
详情请见:
https://www.em.avnet.com/Support%20And%20Downloads/ana_bf518f_fmc_dev-ug-082410.pdf
和
https://www.em.avnet.com/Support%20And%20Downloads/ana_bf518f_fmc_dev-sch-revb022610.pdf
以及
http://www.analog.com/static/imported-files/data_sheets/ADSPBF512_BF512F_BF514_BF514F_BF516_BF516F_BF518_BF518F.pdf
