三伍微电子GSR1351S 兼容替代SKY13351
2024年03月21日 10:40 发布者:Penny2023
三伍微电子GSR1351S 兼容替代SKY13351GSR1351S: CMOS SOI SPDT Switch0.01-7.2 GHzApplicationsWLAN 802.11a/b/g/n/ac/ax networksISM band radiosLow power T/R systemsFeaturesP0.1dB +32dBm typical @+3.3VLow insertion loss (0.30dB @ 2.5GHz,0.40dB @ 5.8GHz)High isolation (40dB @ 2.5GHz)Low delay, switch time:75~125nS1.0mm x 1.0mm QFN Package(MSL3,260°C per JEDEC-J-STD-020)DescriptionUsing advanced switching technologies, the GSR1351S is a single pole dual throw (SPDT) high power switch in a low cost miniature 1.0 mm × 1.0 mm package. The GSR1351S is ideally suited for applications where high power, low insertion loss and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 7.2 GHz required high power at low control voltage.
