三伍微电子GSR1385S 兼容替代SKY13585
2024年02月29日 13:54 发布者:Penny2023
GSR1385S: CMOS SOI SPDT Switch0.01-7.2 GHzApplicationsWLAN 802.11a/b/g/n/ac/ax networks ISM band radiosLow power T/R systemsFeaturesP0.1dB +32dBm typical @ +3.3VLow insertion loss (0.25dB @ 2.5GHz,0.35dB @ 5.8GHz)High isolation (37dB @ 2.5GHz)Low delay, switch time:75~125nS1.0mm x 1.0mm QFN Package(MSL3,260°C per JEDEC-J-STD-020) Description Using advanced switching technologies, the GSR1385S is a single pole dual throw (SPDT) high power switch in a low cost miniature 1.0 mm × 1.0 mm package. The GSR1385S is ideally suited for applications where high power, low insertion loss and small size are required. Typical applications are for handset systems that connect separate transmit and receive functions to a common antenna, as well as other related handset and general purpose applications. This part can be used in all systems operating up to 7.2 GHz requiring high power at low control voltage.
