SFP with or without -11AC-IPQ4019 VS 11AX-IPQ6010 motherboards What is the difference?
2023年12月25日 15:04    发布者:wallyswifi
11AC-IPQ4019 and 11AX-IPQ6010 motherboards with or without SFP,What is the difference between ?When it comes to whether there is an SFP on the router motherboard, this usually refers to whether the router has an SFP slot. SFP stands for small pluggable optical module and is an interface type used for network devices. The SFP slot allows users to plug fiber optic connectors into the router in order to transfer data across the network.If the router has an SFP slot on the motherboard, then the user can use the SFP module to connect the router to a fiber optic network. This type of connection is generally more reliable than using copper cables because fiber can travel longer distances and is not affected by electromagnetic interference. In addition, the use of SFP modules can also provide higher bandwidth, because the fiber can transmit more data.If there is no SFP slot on the router motherboard, then the user can only connect the router to the network using copper cables. This connection can be affected by electromagnetic interference, and the transmission distance is relatively limited. In addition, routers connected using copper cables may not be able to provide the same bandwidth as routers connected using SFP modules.IPQ4019 and IPQ6010 are high-performance network processing chips commonly used in router design. Both chips support SFP slots, so the advantages of having an SFP slot in a router design are the same.1. Fiber Connection: The SFP slot allows the router to connect to the fiber network using fiber connectors. Compared to traditional copper cable connections, fiber optic connections have higher bandwidth and longer transmission distances. This is important for applications that require high-speed data transmission or connections to long-distance networks.2. Anti-interference: The optical fiber connection is not affected by electromagnetic interference, because the optical signal is not interfered by electromagnetic waves. This makes routers using SFP slots more reliable in electromagnetic interference environments, such as industrial environments or high-density wireless networks.3. Flexibility: The SFP slot allows users to select different types of SFP modules according to their needs, such as optical fiber modules, copper modules or other specific network connection modules. This flexibility allows routers to adapt to different network needs and topologies.4. Scalability: Routers with SFP slots can be designed to extend network connections by adding or replacing SFP modules. This allows the router to adapt to future network needs without having to replace the entire router.To sum up, the advantages of router designs with SFP slots for IPQ4019 and IPQ6010 chips include fiber connectivity, anti-interference, flexibility, and scalability. These advantages make routers with SFP slots more suitable for networking applications that require high performance, reliability, and flexibility.IPQ4019 and IPQ6010 are high-performance network processing chips, and they both have their own advantages.Advantages of IPQ4019 chip:1. High performance: The IPQ4019 chip adopts a quad-core ARM Cortex-A7 processor with a main frequency of up to 717MHz, which has excellent computing power and processing speed.2. Highly integrated: IPQ4019 chip integrates a variety of network interfaces and protocols, including Gigabit Ethernet, 802.11ac Wave 2 Wi-Fi, Bluetooth 5.0 and USB 3.0, which can meet the needs of a variety of network applications.3. Low power consumption: IPQ4019 chip is manufactured by 28 nm process, low power consumption, which can extend the battery life of the router.4. Security: IPQ4019 chip supports hardware accelerated encryption and decryption functions, which can provide higher security and data protection.DR40X9Featuring with industrial-grade IPQ4019/IPQ4029 chipset Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module Support 4.940GHz to 5.825GHz Frequency RangeSupport 2.400GHz to 2.482GHz Support 2 x 5G MMCX Connectors and 2x2.4G MMCX Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth Support 11ABGN/AC Support fixed data rateRoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicalsOur Firmware supports all the modules of QuectelSupport OpenwifiSupport QSDKSupport Openwrt
https://media.licdn.com/dms/image/D5612AQHbDx3Rdf7AYQ/article-inline_image-shrink_1000_1488/0/1703486539487?e=1709164800&v=beta&t=Ab39JiLNjRVh-r1gRiHqV206bTJKTL4Uhxs2pQf0zP4
Advantages of IPQ6010 chip:1. High performance: The IPQ6010 chip uses a quad-core ARM Cortex-A53 processor with a main frequency of up to 1.8GHz, which has higher computing power and processing speed.2. Highly integrated: IPQ6010 chip integrates a variety of network interfaces and protocols, including Gigabit Ethernet, 802.11ax Wi-Fi, Bluetooth 5.0 and USB 3.0, which can meet the needs of higher level network applications.3. Low power consumption: IPQ6010 chip is manufactured by 14nm process, low power consumption, which can extend the battery life of the router.4. Security: IPQ6010 chip supports hardware accelerated encryption and decryption functions, which can provide higher security and data protection.DR6018CQualcomm-Atheros IPQ6010Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data RateSupport: QUECTEL RM500Q-GLSupport: QCN9074 WiFi 6E CardSupport OpenwifiSupport QSDK
https://media.licdn.com/dms/image/D5612AQEkey4QafNMaA/article-inline_image-shrink_400_744/0/1703486597778?e=1709164800&v=beta&t=1IQkTqNNlMtrU9VJyy8H-G6l28t1JxDWqhiNiSiTVII
To sum up, both IPQ4019 and IPQ6010 chips have advantages such as high performance, high integration, low power consumption and security, but the IPQ6010 chip has a higher processor frequency and integrates a higher level of network interfaces and protocols, so it performs better in higher level network applications.Wallys software technology advantages:Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.Hardware technology advantages:We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.Clients: TIP,Facebook, Openwrt, etcEmail:sales@wallystech.comWEB:https://www.wallystech.com/
