基于i.MX6ULL的掉电检测设计与软件测试
2023年11月09日 11:08 发布者:武汉万象奥科
基于i.MX6ULL的掉电检测设计与软件测试基于i.MX6ULL平台设计实现掉电检测功能,首先选择一路IO,利用IO电平变化触发中断,在编写驱动时捕获该路GPIO的中断,然后在中断响应函数中发送信号通知应用程序掉电发生了。https://18821080.s21i.faiusr.com/4/ABUIABAEGAAgt-ywqgYoyIab-wUwgwU4iwI.png图1.1掉电信号IO 驱动代码:#include#include
#definepower_MAJOR 200
staticstruct class *my_class;staticstruct fasync_struct *fasync_queue; //异步通知队列
#defineGPIO_NUM 1 //中断引脚为:GPIO1_1staticunsigned int irq_num;
/* 打开 */intpower_open(struct inode *inode,struct file *filp){ return 0;
/* 关闭 */intpower_release(struct inode *inode,struct file *filp){ return 0;}
ssize_tpower_read(struct file *filp,char __user *buf,size_t count,loff_t *f_pos){
return count;}
ssize_tpower_write(struct file *file,const char __user *buf,size_t count,loff_t*f_pos){
return count;}
staticint my_fasync(int fd, struct file * filp, int on){ int retval; retval=fasync_helper(fd,filp,on,&fasync_queue); /*将该设备登记到fasync_queue队列中去*/ if(retval<0) return retval; return 0;}
staticconst struct file_operations simple_fops={ .owner=THIS_MODULE, .open=power_open, .release=power_release, .read=power_read, .write=power_write, .fasync=my_fasync,};
/* 在中断服务函数中向应用层发送消息-异步通知 */ staticirqreturn_t irq_callback (int irqno, void *dev_id){ printk("irq power-detectworking !\n"); if (fasync_queue) { kill_fasync(&fasync_queue, SIGIO,POLL_IN); } return IRQ_HANDLED;}
intpower_init_module(void){ int rtn; int ret; /* 注册设备驱动 */ ret =register_chrdev(power_MAJOR,"power-detect-test",&simple_fops); if(ret<0){ printk("Unable toregister character device %d!/n",ret); return ret; }
/* 自动创建设备节点 */ my_class = class_create(THIS_MODULE,"my_class"); device_create(my_class, NULL,MKDEV(power_MAJOR, 0), NULL,"powerdetect");
/*gpio申请*/ rtn = gpio_request(GPIO_NUM,"my_irq"); if(rtn!=0){ printk("my_irq irq pinrequest io failed.\n"); } rtn = gpio_direction_input(GPIO_NUM); if(rtn<0){ printk("gpio_direction_input()failed !\n"); } /*获取gpio中断号*/ irq_num = gpio_to_irq(GPIO_NUM);
/*GPIO中断服务函数注册,*/ /*下降沿触发*/ rtn = request_irq(irq_num,irq_callback,IRQF_TRIGGER_FALLING,"my_irq", NULL); if (rtn<0) { printk("my_irq requestirq false\n"); } else { printk("my_irq requestirq success: %d\n",irq_num); }
printk("module_initsucessful!!!\n"); return 0;}
/* 卸载 */ voidpower_cleanup_module(void){ /* 卸载相应的设备驱动 */ unregister_chrdev(power_MAJOR,"power-detect-test"); device_destroy(my_class,MKDEV(power_MAJOR,0)); class_destroy(my_class);
/*释放GPIO*/ gpio_free(GPIO_NUM);
printk("module_exitsucessful!!!\n");}
/* 宏实现 */module_init(power_init_module);module_exit(power_cleanup_module);
/* 开源许可声明 */ MODULE_LICENSE("GPL");MODULE_AUTHOR("Zou"); 应用代码:#include
staticint fd;
/* 内核产生异步通知,调用该应用层函数处理 */voidsigterm_handler(int signo){ printf("app irq work !!!\n");}
intmain(void) { int oflags;
fd=open("/dev/powerdetect",O_RDWR); //打开设备文件
/* 启动异步通知信号驱动机制 */ signal(SIGIO, sigterm_handler); fcntl(fd, F_SETOWN, getpid()); oflags = fcntl(fd, F_GETFL); fcntl(fd, F_SETFL, oflags | FASYNC);
/*建立一个死循环,防止程序结束 */ while(1) { printf("sleep\n"); usleep(200000); //2ms }
close(fd); return 0; }将驱动编译成模块,上电加载并执行应用程序后,将电压缓慢下调至掉电临界点。触发GPIO下降沿中断,并提供应用程序掉电信号。https://18821080.s21i.faiusr.com/4/ABUIABAEGAAguvywqgYontajkwIwxgU4lQM.png图1..2掉电检测
