ZCC1496-600KHz, 18V,2A Synchronous Step-Down Converter
2023年09月20日 16:10 发布者:XX9
FEATURES
High Efficiency: Up to 98%
500KHz Frequency Operation
2A Output Current
No Schottky Diode Required
4.0V to 18V Input Voltage Range
0.6V Reference
Slope Compensated Current Mode
Control for Excellent Line and
Load Transient Response
Integrated internal compensation
Stable with Low ESR Ceramic Output
Capacitors
Over Current Protection with
Hiccup-Mode
Thermal Shutdown
Inrush Current Limit and Soft Start
Available in SOT23-6 Package
-40°C to +85°C Temperature Range
APPLICATIONS
Distributed Power Systems
Digital Set Top Boxes
Flat Panel Television and Monitors
Wireless and DSL Modems
Notebook Computer
GENERAL DESCRIPTION
The ZCC1496
is a fully integrated, high
efficiency 2A synchronous rectified step
down converter. The ZCC1496
operates
at high efficiency over a wide output current
load
range.
This
device
offers
two
operation modes, PWM control and PFM
Mode switching control, which allows a
high efficiency over the wider range of the
load. The ZCC1496
requires a minimum
number of readily available standard
external components and is available in a
6-pin SOT23-6 compliant package。
