7V 1.5A 1.25MHz Step-up 10 White LED Driver ZCC3302 替代MP3302
2023年08月15日 14:41 发布者:我心随我
7V 1.5A 1.25MHz Step-up10 White LED Driver ZCC3302 替代MP3302GENERAL DESCRIPTION The ZCC3302 is a 7.5V step-up DC/DC converter designedfor driving up to single 10-series or 9x3-series WLEDs from a single cellLithium Ion- battery. The ZCC3302 usescurrent mode, fixed frequency architecture to regulate the LED current, whichis measured through an external current sense resistor. Its low 300mV feedbackvoltage reduces power loss and improves efficiency. The ZCC3302 supports hig-hfrequency PWM Dimming through EN pin. The ZCC3302 is turned off if anopen-circuit condition is presented. Please be noted that open-circuitcondition is not the same as over-voltage condition.. Please refer to theOPERATION DESCRIPTION and APPLICATION INFORMATION sections for more detail. TheZCC3302 includes soft-start, under-voltage locko-ut, current limiting andthermal overload protections. The ZCC3302 is available in SOT23-6 package. FEATURES ■ Operating Voltage: 2.5-7.5V ■ Maximum Output Voltage: 35V, capable of driving 10-series White LED strings ■ Maximum drive Capability: 9x3- series or 6x6-series. ■ Up to 90% Efficiency ■ 1.25MHz Fixed Switching Frequency ■ Low 300mV Feedback Voltage ■ Support PWM Dimming ■Open-circuit Protection ■ UVLO,Soft-Start and Thermal Shutdown ■ Internal1.5A Current Limit ■ SOT23-6Package APPLICATIONS ■ 5~7” LCDPanels ■ HandheldComputers and PDAs ■ DigitalCameras ■ Small LCDDisplays
