Freescale i.MX53xA SABRE平台参考设计
2011年11月28日 22:30 发布者:1046235000
Freescale公司的i.MX53xA系列是汽车信息娱乐处理器,采用先进的ARM内核,包括3D和2D图像处理器,1080i/p视频处理以及双显示,时钟速率高达800MHz,具有DDR2/LVDDR2-800, LPDDR2-800或DDR3-800 DRAM存储器接口,主要用在汽车,仪表盘,导航,运程信息处理系统,工业以及人机接口(HMI).本文介绍了i.MX53xA处理器主要特性,方框图,以及快速设计智能应用蓝图(SABRE)平台主要特性,框图,电路图,材料清单和PCB布局图.The MCIMX53xA (i.MX53xA) automotive infotainment processor is Freescale Semiconductor’s latest addition to a growing family of multimedia-focused products offering high performance processing with a high degree of functional integration aimed at the growing automotive infotainment, telematics, HMI, and display-based cluster markets. This device includes 3D and 2D graphics processors, 1080i/p video processing, and dual display, and provides a variety of interfaces.
The i.MX53xA processor features Freescale’s advanced implementation of the ARM™ core, which operates at clock speeds as high as 800 MHz and interfaces with DDR2/LVDDR2-800, LPDDR2-800, or DDR3-800 DRAM memories. This device is well suited for graphics rendering for HMI, navigation, high performance speech processing with large databases, video processing and display, audio playback, and many other applications.
The flexibility of the i.MX53xA architecture allows for its use in a wide variety of applications. As the heart of the application chipset, the i.MX53xA processor provides all the interfaces for connecting peripherals, such as WLAN, Bluetooth™, GPS, hard drive, camera sensors, and dual displays.
i.MX53xA处理器主要特性:
Features of the i.MX53xA processor include the following:
• Multilevel memory system—The multilevel memory system of the i.MX53xA is based on the L1 instruction and data caches, L2 cache, internal and external memory. The i.MX53xA supports many types of external memory devices, including DDR2, low voltage DDR2, LPDDR2, DDR3, NOR Flash, PSRAM, cellular RAM, NAND Flash (MLC and SLC), OneNAND™, and managed NAND including eMMC up to rev 4.4.
• Smart speed technology—The i.MX53xA device has power management throughout the IC that enables the rich suite of multimedia features and peripherals to consume minimum power in both active and various low power modes. Smart speed technology enables the designer to deliver a feature-rich product requiring levels of power far lower than industry expectations.
• Multimedia powerhouse—The multimedia performance of the i.MX53xA processor ARM core is boosted by a multilevel cache system, Neon (including advanced SIMD, 32-bit single-precision floating point support) and vector floating point coprocessors. The system is further enhanced by a multi-standard hardware video codec, autonomous image processing unit (IPU), and a programmable smart DMA (SDMA) controller.
• Powerful graphics acceleration— The i.MX53xA processors provide two independent, integrated graphics processing units: an OpenGL® ES 2.0 3D graphics accelerator (33 Mtri/s, 200 Mpix/s, and 800 Mpix/s z-plane performance) and an OpenVG™ 1.1 2D graphics accelerator (200 Mpix/s).
• Interface flexibility—The i.MX53xA processor supports connection to a variety of interfaces, including LCD controller for two displays and CMOS sensor interface, high-speed USB on-the-go with PHY, plus three high-speed USB hosts, multiple expansion card ports (high-speed MMC/SDIO host and others), 10/100 Ethernet controller, and a variety of other popular interfaces (PATA, UART, I2C, and I2S serial audio, among others).
• Automotive environment support—Includes interfaces such as two CAN ports, an MLB port, an ESAI audio interface, and an asynchronous sample rate converter for multichannel/multisource audio.
• Advanced security—The i.MX53xA processors deliver hardware-enabled security features that enable secure e-commerce, digital rights management (DRM), information encryption, secure boot, and secure software downloads. For detailed information about the i.MX53xA security features contact a Freescale representative.
The i.MX53xA application processor is a follow-on to the i.MX51xA, with improved performance, power efficiency, and multimedia capabilities.
i.MX53xA目标应用:
Automotive
Instrument Cluster
Navigation
Telematics
Industrial
Human Machine Interface (HMI)
图1. i.MX53xA系统框图
快速设计智能应用蓝图(SABRE)平台
Freescale delivers the ultimate in performance and design flexibility with its Smart Application Blueprint for Rapid Engineering (SABRE) platform for Automotive Infotainment based on the i.MX53 family of automotive applications processors. A high-performance market-focused development system, the SABRE for Automotive Infotainment offers a solid foundation for any next generation infotainment platform design. The i.MX53 family of automotive applications processors represents Freescale’s next generation of advanced multimedia and power-efficient implementation of the ARM Cortex™-A8 core for the automotive market. With core processing speeds up to 1GHz as well as a high level of integration, this full-featured development platform enables customers to re-create today’s consumer user experiences in the car.
A range of highly flexible connectivity options makes the SABRE for Automotive Infotainment based on i.MX53 ideal for developing many different types of advanced infotainment applications. The platform is designed to support many off-the-shelf peripherals for automotive infotainment such as terrestrial and satellite radio tuners, WiFi, Bluetooth, GPS, cellular modem, iAP authentication modules, MOST and CAN vehicle networking, cameras and displays. The SABRE for Automotive Infotainment is also a modular platform, allowing customers to integrate the SABRE for Automotive Infotainment i.MX53 CPU card into their own systems to rapidly prototype solutions with a custom peripheral set.
图2. 快速设计智能应用蓝图(SABRE)平台外形图
This document is the Hardware Reference Manual for the i.MX53 Quick Start board based on the Freescale Semiconductor i.MX53 Applications Processor. This board is fully supported by Freescale Semiconductor. This Manual includes system setup and debugging, and provides detailed information on the overall design and usage of the i.MX53 Quick Start board from a Hardware Systems perspective.
The Quick Start Board is an i.MX535 platform designed to showcase many of the most commonly used features of the i.MX535 Applications Processor in a small, low cost package. The MCIMX53-START is an entry level development board and a near perfect subset of its larger sister board, the MCIMX53SMD, which is available as a full, near-form factor tablet. Developers can start working with code on the Quick Start board, and then port it over to the SMD Tablet if additional features are desired. This gives the developer the option of becoming familiar with the i.MX535 Applications Processor before investing a large amount or resources in more specific designs.
i.MX53快速入门板主要特性:
The i.MX53-Quick Start Board comes with the following items:
_ i.MX53-QUICK START Board
_ microSD Card preloaded with Ubuntu Demonstration Software
_ USB Cable (Standard-A to Micro-B connectors)
_ 5V/2.0A Power Supply
_ Quick Start Guide
_ Documentation DVD
图3. SABRE平台方框图
图4. SABRE平台电路图(1)
图5. SABRE平台电路图(2)
图6. SABRE平台电路图(3)
图7. SABRE平台电路图(4)
图8. SABRE平台电路图(5)
图9. SABRE平台电路图(6)
图10. SABRE平台电路图(7)
图11. SABRE平台电路图(8)
图12. SABRE平台电路图(9)
图13. SABRE平台电路图(10)
图14. SABRE平台电路图(11)
图15. SABRE平台电路图(12)
图16. SABRE平台电路图(13)
SABRE平台材料清单:
图17. SABRE平台电PCB布局图(顶层)
图18. SABRE平台PCB布局图(底层)
详情请见:
51514和
51515以及
51516
CAN总线测试分析
我公司提供的CAN总线测试产品是汽车/坦克领域、工业自动控制领域和医疗设备领域等工程师首先的测试工具和产品。系列接口产品有如下接口产品:
以上测试仿真板卡具有如下主要特点:
★ 支持CAN2.0A和CAN2.0B总线协议
★ 支持高、低速的波特率
★ 大容量内存,能存储大量的CAN总线消息
★ 单、双或者四通道的CAN总线接口
★ 有CAN总线监听功能
★ 有CAN总线分析功能
★ 有故障检测和故障注入功能
Xtm(CAN总线分析、仿真工具)
软件介绍
Xtm是一个用于控制嵌入式网络节点(电子控制单元)的软件环境。它也可用于显示和修改那些网络节点的内部状态。此外,用户能够模拟和分析嵌入式网络节点之间的通信,并且如果需要的话,用户还可以通过网络行为的仿真来替换丢失的网络节点。Xtm同样也可用于改变和完善网络通信。
目前支持的网络有:CAN,LIN,以太网(仅UDP)和FlexRay。通过一个外接的ECU,PC机的串口和K-line(通过相关的LAPcan卡适配器)也可用于通信。
在测量或通用网络通信的同时,视频流的记录和再传送也是可能的。视频流和测量数据可以时间同步。
Xtm有一个模块化设计:例如,硬件接口的实现和通信协议在最底层。接口被建立和参数化,但当正常运行Xtm时是不可见的。仅仅当接口生成产物(数据和信号)的时候,是可见的。
Xtm是EK Tronic和Kornwestheim合并后的产物。许多基于Xtm的用户定制的项目已经成为现实。
主要特性
★ 显示CAN/LIN/FlexRay消息
★ 支持ASAP2文件和CCP/XCP测量
★ 记录和再传送视频流
★ 强大的script语言,可进行复杂的CAN总线测试与仿真
★ 模拟信号的图像表达功能
★ 基于DBC和LDF描述文件解码和生成CAN/LIN消息
★ 有CAN/LIN消息的发送窗口
★ 触发对象
★ 面板窗口用于script程序和仿真信号的控制
★ 高性能以及很好的实时特性
公司简介: 公司是中关村科技园区高新技术企业、北京市双软认定企业、中关村信用联盟星级会员、北京市守信企业、国家军用标准GJB9001A质量体系认证企业、军工保密资格认证单位、世界首席嵌入式芯片构架设计公司—ARM在中国唯一的授权培训中心。公司还获得了国家密码管理局颁发的“商用密码产品销售许可证”、“商用密码产品生产定点单位”证书,航天部合格供应商称号。 公司按照新标准被认定为2008年第一批国家级高新技术企业。 ...>>
联 系 人: 王先生
电 话: 021-64326688-617手 机: 15800481807电子邮箱: qiu.shenwang@163.com所在城市: 上海市[上海]
详细地址: 上海市古美路1528号A3栋2楼公司网站: http://www.watertek.com
