High performance router-IPQ8072-4x4 2.4G & 5G-MU-MIMO OFDMA-support QCN9074
2023年06月20日 10:42 发布者:wallyswifi
High performance router-IPQ8072-4x4 2.4G & 5G-MU-MIMO OFDMA-support QCN9074As wifi technology becomes more and more mature, there are more and more requirements for software development. For more industrial projects, a higher and more stable wireless solution is required, which means that the requirements for motherboard chips are becoming more and more stringent. IPQ8072 is one of the high-performance products. Let’s take a look at some of its special features and why it can win the high-performance requirements of industrial projects.
Wallys is a company that develops, manufactures and designs wifi products, and also launches router motherboards with IPQ8072 chips, Support WiFi 6E Card, 802.11ax, QCN9074, IPQ8072 4x4 2.4G & 5G 802.11ax .
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash (NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Wireless
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain
8x U.FL Connectors
IPQ8072 is a high-performance network processing chip launched by Qualcomm (Qualcomm). The following are several advantages of the IPQ8072 chip:
High-performance processing capability: IPQ8072 adopts multi-core design, which has powerful processing capability and high-speed data transmission capability. It is equipped with four Krait CPU cores, clocked at up to 2.2GHz, capable of handling complex network tasks and massive data streams.
Multifunctional integration: The IPQ8072 chip has built-in rich hardware accelerators and network protocol processing engines, including high-speed Ethernet switches, data packet processing engines, hardware encryption engines, etc. The integration of these functions enables the IPQ8072 to efficiently process packets, reduce network latency, and provide better performance and response speed.
High-speed connectivity and bandwidth support: such as 2.5Gbps and 10Gbps Ethernet interfaces, and multiple PCIe Gen3 interfaces. This high-speed connection and bandwidth support can meet the needs of industrial projects for high-speed data transmission and communication, and provide stable and reliable network connections.
Strong security performance: IPQ8072 chip has advanced security functions, including hardware encryption engine, virtual private network (VPN) accelerator and firewall functions. These security features can effectively protect the confidentiality and integrity of network data and provide a more secure network environment.
Flexible software support: The IPQ8072 chip adopts an open software architecture and supports multiple operating systems and network protocol stacks. Developers can use a wide range of software tools and development environments for customized application development and system integration to meet different network requirements and application scenarios.
The IPQ8072 chip has the advantages of high performance, multi-functional integration, high-speed connection, strong security performance and flexible software support in industrial projects, and can meet the requirements of industrial projects for processing power, data transmission and security.
Wallys has over 15 years of research and development experience, experienced in linux, wifi protocol and other aspects, Qualcomm chip development drivers, kernel and other important software development, modification and compilation, to meet customers' different wifi functional needs.
We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
Clients: TIP,Facebook, Openwrt, etc
Email:sales@wallystech.com
WEB:https://www.wallystech.com/
