IPQ9574+QCN9274 Wireless solution/Support dual-band 2.4GHz and 5GHz at the same time
2023年04月17日 15:14 发布者:wallyswifi
IPQ9574+QCN9274 Wireless solutionBoth IPQ9574 and QCN9274 are high-performance wireless solutions that are mainly used in Wi-Fi routers, network storage devices, and smart home devices. IPQ9574 is a high-end chip suitable for high-performance routers, while QCN9274 is a low-power Wi-Fi module suitable for small IoT devices.
These two chips can work together to form a complete wireless network solution. The IPQ9574 provides the core functions of a high performance router, while the QCN9274 provides a reliable Wi-Fi connection for high-speed, stable wireless network connection.
Specifically, the IPQ9574 features a quad-core ARM Cortex-A53 processor and a high-performance network acceleration engine that supports up to four streams of MU-MIMO and 802.11ac Wave 2 standards while supporting multiple frequency bands, including 2.4GHz and 5GHz. QCN9274 uses a high-performance Wi-Fi chip that supports 802.11a/b/g/n/ac and dual-band 2.4GHz and 5GHz, providing high-speed and stable Wi-Fi connectivity.
In short, the combination of IPQ9574 and QCN9274 can provide high performance, stable wireless network solutions, suitable for a variety of applications.
Are they in the wifi7 range?
Neither IPQ9574 nor QCN9274 support Wi-Fi 7. The latest Wi-Fi standard they support is 802.11ac Wave 2, which has a maximum theoretical speed of 1733Mbps. Wi-Fi 7 is the latest Wi-Fi standard, also known as 802.11be, with a theoretical top speed of 30Gbps.
Although the IPQ9574 and QCN9274 do not support the Wi-Fi 7 standard, they are still very powerful and high-performance wireless solutions for a variety of applications requiring high-speed, stable wireless connections. At the same time, the Wi-Fi 7 technology is still in its development stage, and only a handful of manufacturers have released products supporting the standard.
The combination of IPQ9574 and QCN9274 can achieve a maximum theoretical rate of 1733Mbps. IPQ9574 is a high performance router chip that supports 4x4 MU-MIMO and 802.11ac Wave 2 standards and can deliver theoretical rates of up to 1733Mbps. QCN9274 is a high-performance Wi-Fi chip that supports 802.11a/b/g/n/ac with a maximum theoretical speed of 300Mbps.
How fast can they combine
When combined, the two chips can achieve speeds of up to 1,733 MBPS. But the actual speed can be affected by a variety of factors, such as signal strength, distance, obstacles, etc. Therefore, the actual rate may be lower than the theoretical rate.
How many frequencies can you have at once?
Both IPQ9574 and QCN9274 support multiple bands. The IPQ9574 supports both 2.4GHz and 5GHz bands and can support multiple channels working simultaneously, providing more bandwidth and better wireless coverage. QCN9274 also supports dual-band 2.4GHz and 5GHz, and can support multiple channels working simultaneously to provide better wireless connectivity and greater network capacity.
In practical applications, the simultaneous use of multiple frequency bands can improve network performance and stability. Through proper planning of frequency bands, congestion and interference can be reduced, and network throughput and reliability can be improved. At the same time, multiple frequency bands can also support more devices to connect to the wireless network to meet the bandwidth requirements of different devices.
Wallys software technology advantages:
Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. Mainly use Qualcomm chip, open
Send drivers, kernel and other important software, have the ability to modify and compile, to meet customers' different wifi functional needs, and participate in openwrt organization, code development, wifi5 products
DR40x9 has been officially supported by openwrt.
Hardware technology advantages:
There is a strong hardware design team, experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team has zero error to achieve signal integrity, such as
Network adapter frequency conversion, from 2.4G to 900M, this is a technical breakthrough.
Clients: TIP,Facebook, Openwrt, etc
