Wallys|DRC-AP5159 Featuring with industrial-grade IPQ4019/IPQ4029 chipset
2023年03月20日 13:29 发布者:hia
Featuresl Featuring with industrial-grade IPQ4019/IPQ4029 chipset The IPQ4019 and IPQ4029 are both chipsets developed by Qualcomm. These chipsets are designed for use in wireless routers and other networking devices, and they are based on a quad-core ARM Cortex-A7 processor.The IPQ4019 is a mid-range chipset that supports up to 867 Mbps of 802.11ac Wi-Fi throughput and is commonly used in residential and small business routers. The IPQ4029 is a higher-end chipset that supports up to 2.2 Gbps of 802.11ac Wi-Fi throughput and is often used in enterprise-level networking equipment.Both chipsets include hardware acceleration for VPNs, support for multi-user MIMO, and advanced QoS features. They also support a wide range of networking protocols and interfaces, making them highly flexible and customizable for various networking applications. l Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module 5G high power radio modules are designed for use in 5G cellular networks and are capable of transmitting and receiving data at very high speeds. These modules typically operate in the millimeter wave (mmWave) frequency band, which is above 24 GHz, and require advanced technologies such as beamforming and massive MIMO to overcome the high propagation loss at these frequencies. High power versions of these modules are designed to provide greater coverage and higher throughput in areas with weaker signal strength. 2.4G high power radio modules, on the other hand, operate in the 2.4 GHz frequency band and are commonly used in wireless communication systems such as WiFi, Bluetooth, and Zigbee. These modules typically have lower power requirements than 5G modules, but high power versions are available for use in applications that require greater range or penetration through obstacles such as walls or floors. Both 5G high power radio modules and 2.4G high power radio modules are used in a variety of applications including telecommunications, industrial automation, smart homes, and Internet of Things (IoT) devices.l Support 4.940GHz to 6.1GHz Frequency RangeThis frequency range is within the unlicensed band of the radio spectrum and is commonly used for various wireless communication applications, such as: WiFi: The IEEE 802.11a standard operates in the 5 GHz frequency range, including the range of 5.15 GHz to 5.85 GHz. This standard provides high-speed wireless connectivity for local area networks (LANs) and is commonly used in homes, offices, and public areas. 5G: The 5G NR (New Radio) standard uses frequencies in the range of 3.3 GHz to 4.2 GHz and 4.4 GHz to 5.0 GHz, as well as the millimeter wave (mmWave) frequencies above 24 GHz. The 5G network is designed to provide high-speed data transfer, low latency, and greater capacity for mobile communication. WirelessHD: This standard operates in the 60 GHz frequency range and is used for high-speed wireless communication between devices such as TVs, projectors, and Blu-ray players. Wireless gigabit Ethernet: This technology uses the 60 GHz frequency band to provide high-speed data transfer between devices. Other applications that may use this frequency range include radar, satellite communication, and military communication systems. l Support 2.400GHz to 2.482GHz The frequency range of 2.400GHz to 2.482GHz is commonly used for various wireless communication technologies such as Wi-Fi, Bluetooth, and Zigbee. These technologies utilize the radio waves in this frequency range to transmit and receive data wirelessly between devices. The 2.4GHz frequency range is widely used due to its availability, low cost, and ability to transmit data over short distances.l Support 2 x 5G MMCX Connectors and 2x2.4G MMCX These are specifications commonly used in the context of wireless communication systems, specifically for antennas used in wireless routers, access points, and other networking equipment. The "2 x 5G MMCX Connectors" refer to two connectors that support 5 GHz frequency bands and use the MMCX (Micro-Miniature Coaxial) connector interface. This means that the antenna can be connected to two separate 5 GHz radios or devices simultaneously. Similarly, the "2x2.4G MMCX" refers to two connectors that support 2.4 GHz frequency bands and use the MMCX interface. This allows the antenna to be connected to two separate 2.4 GHz radios or devices simultaneously. Overall, the use of multiple connectors and frequency bands allows for greater flexibility and improved performance in wireless communication systems.l Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth Bandwidth refers to the range of frequencies that can be used to transmit data over a communication channel. The bandwidth of a channel determines the amount of data that can be transmitted over it per unit of time. The bandwidth options you listed - 5MHz, 10MHz, 20MHz, 40MHz, and 80MHz - are commonly used in wireless communication systems such as Wi-Fi and cellular networks. These bandwidth options refer to the width of the frequency band that is available for data transmission. In general, a larger bandwidth allows for higher data rates, but also requires more power and may be more susceptible to interference. The choice of bandwidth depends on the specific requirements of the communication system and the available resources.l Support 11ABGN/AC 802.11a: This standard operates in the 5 GHz frequency band and supports data rates up to 54 Mbps. 802.11b: This standard operates in the 2.4 GHz frequency band and supports data rates up to 11 Mbps. 802.11g: This standard operates in the 2.4 GHz frequency band and supports data rates up to 54 Mbps. 802.11n: This standard operates in both 2.4 GHz and 5 GHz frequency bands and supports data rates up to 600 Mbps. 802.11ac: This standard operates in the 5 GHz frequency band and supports data rates up to several Gbps. Therefore, "Support 11ABGN/AC" means that the device is compatible with multiple Wi-Fi standards and can operate in both the 2.4 GHz and 5 GHz frequency bands, supporting high data rates up to several Gbps.l RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicalsl 19dbi 5GHz/16dbi 2.4GHz antenna (optional)SymbolParameter
CPUIPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet 2xRJ45
SFP connector1xSFP fiber module connector (optional)
3G/4G connector1xminipcie 3G/4G connector support with two sim card
USB connector1xUSB 3.0 connector
POE24V~48V passive POE
DC Jack24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR256MB~512MB
Operating ModeData RatePowerTolerance
1 Chain2 Chains
802.11a6 Mbps27dBm30dbm±2dB
54 Mbps23dBm26dbm±2dB
802.11n HT20MCS0, MCS826dBm29dbm±2dB
MCS7, MCS1522dBm25dbm±2dB
802.11n HT40MCS0, MCS825dBm28dbm±2dB
MCS7, MCS1521dBm24dbm±2dB
802.11acMCS0, MCS10,MCS2025dBm28dbm±2dB
MCS9,MCS19,MCS2919dBm22dbm±2dB
Wallys Communications (SuZhou) Co., Ltd., http://www.wallystech.com,which is mainly engaged in the research and development and production of wireless communication products,providing superior OEM/ODM/JDM services in wireless communications and customer-specific solution.In addition to the PCBA mainboard, we can also customize indoor or outdoor antennas, which we have extensive experience in. There is also the Tooling. We can do the Tooling for the customer, to undertake a variety of materialsmainly metal and plastic enclosure production. Whether antenna enclosure or router enclosure, we can customize for you. Besides of the Qualcomm chips we currently use, we can also use different chips to design according to customers' needsMAIL:sales3@wallystech.comWEB:https://www.wallystech.com/
