Wallys\\wifi6 routerboard/IPQ6010 openwrt QSDK QCN9074/QCN9024 M.2 moudles
2023年02月08日 16:43 发布者:wallyswifi
Wallys\\wifi6 routerboard/IPQ6010 openwrt QSDK QCN9074/QCN9024 M.2 moudlesQCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax,2x2 2.4G&5G 2.5Gbps Ethernet Port Support OpenWRT Support:QUECTEL RM500Q-GL&Support:Qualcomm-Atheros IPQ6010Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data RateSupport: QUECTEL RM500Q-GLSupport: QCN9074 WiFi 6E CardAbsolute Maximum Rating
ParameterRatingUnit
Supply Voltage24V~48V
Operating Temperature Range-40 to +70oC
Storage Temperature Range-45 to +105oC
Operating Humidity Range5 to +95 (non-condensing)%
Hardware Specifications
SymbolParameter
CPUQualcomm-Atheros IPQ6010
CPU FrequencyQuad-core ARM 64 bit A53 @1.8 GHz processor
System Memory1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF SlotM.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot1x SD Card Slot
USB /header1x USB 2.0 Port
POE24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack24V power supply
LED headerFFC/FPC Connector
Serial Port1x Serial Port 4 Pin Connector
WirelessOn-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain4 x MMCX Connectors
Bluetoothoptional
Nor Flash8-32MB(normally is 8MB)
Nand Flash256MB
DDR1GB
Dimension 185mm x 116mm
Boot Config Switch
Boot_Config Switch1(S7)
Boot_ConfigBoot up InterfaceSelect
S7AS7BS7C
000SPI NOR. (Default)
001eMMC
010QPIC, Parallel NAND
011USB2.0
100SPI-NOR-GPT
S7DBoot up InterfaceSelect
0Boot from code ram.(Default)
1Boot from ROM
Boot_Config Switch2(S9)
0No auth.(Default)
1Auth is required
Interface MAP
APPLICATIONS+ Profi WiFi hotspot coverage+ Commercial radio coverage+ Hotel Wireless application+ Country coverage+ Internet for passengers (bus, train, plane, …)+ Security Surveillance+ Some special scene application+ Heavy-duty industrial environment useWith over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective router boards , wireless network cards,antenna ,enclosure and etc., Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.Skype/EMAIL/Teams:sales@wallystech.comWEB:https://www.wallystech.com/
