MINI PCIE moudle/MT7915 QCN9074/QCN9024 QCA9880 QCA9882 Wallys industrial wifi moudle
2022年12月15日 11:02 发布者:wallyswifi
MINI PCIE moudle/MT7915 QCN9074/QCN9024 QCA9880 QCA9882 Wallys industrial wifi moudleNow that wireless communication is becoming more and more popular, any industry will need it.
wallys keeps up with the development trend of science and technology, and is developing, designing and producing more wifi products to meet the needs of various industries for wifi.
The mini pcie moudle is one of the requirements. The following will introduce what the mini pcie interface is.
mini pcie is based on the PCI-E bus and has better bandwidth than traditional PCI interfaces. Can be extended on the motherboard, such as mini-pcie interface SSD, wireless network card, 3G network card, TV card, mini pci-e to CF card module, Bluetooth card and so on rich expansion functions.
https://bbs.ecer.com/upload/tmp/705136_5GYZQEE7QQY5NYE.png
MINI PCI-E is based on the PCI-E bus interface, mainly used in notebooks and digital devices. It uses the peer-to-peer serial connections that are now popular in the industry, with each device having its own dedicated connection rather than the shared parallel architecture of PCI and earlier computer buses.
PCIe ports can be connected to PCIe X1, PCIe X4, and PCIe X16 based on their specifications.
PCIe X1
PCIe X1 is the smallest PCIe interface and is located the farthest away from the CPU. Common hardware that needs to be used for PCIe X1 ports includes independent sound cards and independent network adapters. These hardware are usually added because the hardware performance of the mainboard cannot meet user requirements. Therefore, they are not necessary upgrades.
PCIe X4
PCIe X4 is a PCIe interface with a higher frequency than PCIe X1. It is mostly used to connect video capture cards and PCIe solid-state drives. Especially for solid state drives, PCIe interfaces can greatly improve the data exchange speed between the hard disk and the processor.
PCIe X16
PCIe X16 is the most frequently used specification and the one closest to the processor. This specification interface is used to access independent graphics card, greatly improve the display performance of the whole machine.
Through the above introduction, I believe you have a certain understanding of mini pcie. Of course, those who are knowledgeable certainly do not need to explain more.
Then the following is a simple introduction to wallys several mini pcie moudle. If you need more parameters, please visit wallys website:https://www.wallystech.com/Network_Card.html
DR7915
WiFi6 MiniPCIe Module 2T2R
2×2.4GHz 2x5GHz MT7915 MT7975
MT7915+MT7975 Chipset2.4GHz max 23dBm & 5GHz max 20dBm output power IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n 2×2 2.4G & 2×2 5G MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector SupporttheFrequency2412MHz~2482MHzSupporttheFrequency5180MHz~5825MHz
https://bbs.ecer.com/upload/tmp/705136_ZSKSNPRJM8Q7ZN2.jpg
DR9074E
WiFi6 and WiFi6E 4x4 MU-MIMO QCN90X4 Dual Band WiFi Module
■ Qualcomm Atheros QCN90X4■ Maxim Tx power 20dBm per chain■ Data Rateup to 4949Mbps■ Support 5.180~5.825Ghz or 5.925GHz-7.125GHz or 5.180GHz- 7.125GHz■ MiniPCIe connector■ PCI Express 3.0 Interface
https://bbs.ecer.com/upload/tmp/705136_SDU9VZHXMVYZW96.jpg
DR900VX
QCA9880 802.11ac Dual band
QCA9880 3x3 2.4G/5G FCC/CE/IC
Qualcomm-Atheros QCA9880 chipset2.4GHz max 26dBm & 5GHz max 25dBm output power IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n 3x3 MIMO Technology, up to 1.3Gbps Mini PCI Express edge connector
https://bbs.ecer.com/upload/tmp/705136_63DHB34YU5FU2RD.jpg
DR600VX
QCA9880 2x2 2.4G/5G FCC/CE
Qualcomm-Atheros QCA9880 chipset2.4GHz max 24dBm & 5GHz max 23dBm output power IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n 2x2 MIMO Technology, up to 867Mbps Mini PCI Express edge connector Support the Frequency 4920MHz~4980MHz
https://bbs.ecer.com/upload/tmp/705136_KQPWC4PPQATQ4AN.jpg
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective router boards , wireless network cards,antenna ,enclosure and etc., Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
You are welcome to consult more, happy to answer questions for you.Skype/EMAIL/Teams:sales@wallystech.com
