ZCC103数字温度传感器芯片替代TMP103
2022年12月13日 16:50 发布者:我心随我
ZCC103数字温度传感器芯片替代TMP1031 DescriptionThe ZCC103 is adigital output temperature sensor in a four-ball wafer chip-scale package(WCSP). The ZCC103 is capable of reading temperatures to a resolution of 1°C.The ZCC103 features a two-wire interface that is compatible with both I2C andSMBus interfaces. Inaddition, theinterface supports multiple device access (MDA) commands that allow the masterto communicate with multiple devices on the bussimultaneously, eliminatingthe need to send individual commands to each ZCC103 on the bus. Up to eightZCC103s can be tied together in parallel and easily read by the host. TheZCC103 is especially suitable for space-constrained, power-sensitiveapplications with multiple temperature measurement zones that must bemonitored.The ZCC103 isspecified for operation over a temperature range of –40°C to 125°C 2 FeaturesMultiple DeviceAccess (MDA):Global Read/WriteOperationsI2C™ andSMBus™-Compatible Interface Resolution: 8 BitsAccuracy: ±1°CTypical (–10°C to 100°C)Low QuiescentCurrent:3-μAActiveIQat0.25Hz1-μA ShutdownSupply Range: 1.4V to 3.6 VDigital Output 3 Applications•Handests•Notebooks•SSDs•Servers•Telecom•Set TopBoxes•Low PowerEnvironmertal•Sensors
