Industrial wifi6 Wireless AP/DR AP6018 S AIPQ6010 2T2R 2.4G&5G high power Radio AP
2022年12月05日 15:24    发布者:Cindy1818
DR-AP6018-S-Ahttps://www.wallystech.com/Industrial_Wireless_AP/DR-AP6018-S-A-wifi6-Access-Point-Qualcomm-IPQ6010-2T2R-supporting-QCN9074-wifi-card-aluminum-body.html Description DR-AP6018-S-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x  DR6018-S (IPQ6010) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);1 x Enclosure. Dipole antenna ■  2 x 2.4G&5G Antenna■  5dBi 2.4GHz/5Ghz■ SMA Plug interface ■ Plastic rod of black ■ RoHS compliance Enclosure■  Dimension: 133x 128 x 44 mm■  Aluminum alloy material■ Two Version: DR-AP6018-S-AB (color black)DR-AP6018-S-AO (color orange)■  Support Wally DR6018-S
Absolute Maximum Rating
ParameterRatingUnit
Supply Voltage24V~48V(DC Jack)V
Operating Temperature Range-40 to +70oC
Storage Temperature Range-45 to +105oC
Operating Humidity Range5 to +95 (non-condensing)%
Hardware Specifications
SymbolParameter
CPUQualcomm-Atheros IPQ6010
CPU FrequencyQuad-core ARM 64 bit A53 @1.8 GHz processor
System Memory1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF SlotM.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot1x SD Card Slot(Option)
USB /header1x USB 3.0 Port(Option)
POE24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack24V~48V power supply
LED header2.0 pitch pin header
Serial Port1x Serial Port 4 Pin Connector
WirelessOn-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chainOn-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain4 x MMCX Connectors
Nor Flash8MB
Nand Flash256MB
DDR256MB~512MB
Dimension 133mm x 128mm x 44mm
We’ll start with a quick review of how Wi-Fi has changed over the years.
In fact, the earliest generation of 802.11 standard can be traced back to 1997, when the wireless speed is very low, only 2Mbps, it is an original standard of the first generation .
With the introduction of 802.11b in 1999, the physical layer speed was increased to 11Mbps and there were very few commercial applications. At that time, Wi-Fi was still far away from people’s lives
In 2003, the third generation of the standard, 802.11a/ g. Laptop began to configure wireless network card and home wireless router appeared in large quantity . Wi-fi comes into ordinary family.
Skype/EMAIL/Teams:sales2@wallystech.com
WEB:https://www.wallystech.com/
