Industrial wifi6 router/wifi6-Qualcomm-IPQ6010/IPQ6018-Wallys
2022年11月30日 15:41 发布者:Cindy1818
MT7915/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ5018/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ4018/IPQ4028/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531. Wallys' products It is also constantly upgraded, from WIFI5 to WIFI6, the chipset is also from IPQ4019 to IPQ8074 and so on, Wallys is always the most cutting-edge wireless technology of the times!EMAIL:sales2@wallystech.comWEB:https://www.wallystech.com/ This section describes three Wallys RouterBoards based on Qualcomm IPQ6010/IPQ6018 chips. DR6018, DR6018C, V01, DR6018S.Let's talk a little bit about the parameters. DR6018 and DR6018C V01, support :QUECTEL RM500Q-GL&Support: QCN9074 WiFi 6 e card, 802.11ax, IPQ6010, support 2.4g&5g OpenWRT 2×2.The difference is that DR6018 does not have SFP and DR6018C V01 has SFP.Compared with the previous two Routerboards, DR6018S has fewer network ports and no SFP. Therefore, DR6018S cannot be used with a moudle. DR6018https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.htmlQCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax,2×2 2.4G&5G 2.5Gbps Ethernet Port Support OpenWRT Support:QUECTEL RM500Q-GL&Support:Qualcomm-Atheros IPQ6010Quad-core ARM 64bit A53 @1.8GHz Processor1GB DDRL3L System Memory32MB NOR Flash, 256MB NAND FlashSupports Dynamic Frequency Selection (DFS)2×2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate2×2 On-board 5GHz radio, up to 1201Mbps physical Data RateSupport: QUECTEL RM500Q-GLSupport: QCN9074 WiFi 6E CardSupport:QUECTEL RM500Q-GL&Support:QCN9074 WiFi 6E Card,802.11ax,IPQ6010
DR6018C V01https://www.wallystech.com/Routerboard/DR6018CV01-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA-SFP.htmlSupport:QUECTEL RM500Q-GL&Support:QCN9074 WiFi 6E Card,802.11ax,IPQ6010Support OpenWRT 2×2 2.4G&5G 2.5Gbps Ethernet Port SFPQualcomm-Atheros IPQ6010Quad-core ARM 64bit A53 @1.8GHz Processor1GB DDRL3L System Memory32MB NOR Flash, 256MB NAND FlashSupports Dynamic Frequency Selection (DFS)2×2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate2×2 On-board 5GHz radio, up to 1201Mbps physical Data RateSupport: QUECTEL RM500Q-GLSupport: QCN9074 WiFi 6E Card
DR6018-Shttps://www.wallystech.com/Routerboard/DR6018-S-V02-wifi6-Qualcomm-IPQ6010-2T2R-2-GE-port-supporting-QCN9074-wifi-card-802.11AX-MU-MIMO-OFDMA.htmlSupport OpenWRT 2×2 2.4G&5GDR6018-S V02 IPQ6010/IPQ6018/IPQ6000Quad-core ARM 64bit A53 @1.8GHz Processor1GB DDRL3L System Memory8MB NOR Flash, 256MB NAND FlashSupports Dynamic Frequency Selection (DFS)2×2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate2×2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
QCN9074/QCN9024/QCN6024 series moudleSupport 2.4G/5G/6G, single frequency.
