Wallys/ industrial mini pcie card/2x 2 5G /High power Radio card
2022年11月24日 11:55 发布者:Cindy1818
DR882https://www.wallystech.com/Network_Card/DR882-Qualcomm-Atheros-QCA9882-2T2R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-5G-high-power.html
Wallys Communications (Suzhou ) Co., LTD(http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period.IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344/AR9531BY:Wallys Communications (Suzhou ) Co., LTDwifi6 router/network cardwifi 6EWiFi 6802.11ax/802.11acwireless solutionsDipole/ panel //Dual Polarization Enclosure /Smart /omni /AntennaWireless Access Point/Point to Point /Featuring with industrial-grade Atheros’s QCA9882 chipsetIntegrated with 2x 2 5G high power Radio Card4.940GHz to 5.825GHz Frequency Range2 x 5G MMCX Connectors20MHz/40MHz/80MHz BandwidthSupport 802. 11AC/ANRoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicalsDR882 is an industrial grade Atheros QCA9882 chipset, which is integrated with two 2.5G high power Radio Card. The frequency range covers the 4.940GHz to 5.825GHz band. It supports 802.11AC/AN and has a 20MHz/40MHz/80MHz bandwidth.It is RoHS compliant, ensuring a high level protection of human health and the environment from risks that can be posed by chemicals.
Absolute Maximum Rating
ParameterRatingUnit
Supply Voltage3.3V(MINIPCIE)V
Operating Temperature Range-40 to +60oC
Storage Temperature Range-65 to +105oC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
SymbolParameter
CPUQCA9882
Antenna Connector2 x 5G MMCX connectors
ROHS ComplianceYES
Dimension50mm x 30mm x 16mm
Radio TX Specifications
Operating ModeData RatePowerTolerance
1 Chain2 Chains
802.11a6 Mbps25dBm28dbm±2dB
54 Mbps21dBm24dbm±2dB
802.11n HT20MCS0, MCS825dBm28dbm±2dB
MCS7, MCS1520dBm23dbm±2dB
802.11n HT40MCS0, MCS825dBm28dbm±2dB
802.11acMCS0, MCS10,MCS2025dBm28dbm±2dB
MCS9,MCS19,MCS2917dBm20dbm±2dB
