Wallys/IPQ4018/IPQ4028 2x2 2.4Ghz 2x2 5Ghz Industrial grade/Support 11ABGN/AC
2022年11月24日 11:28 发布者:Cindy1818
DR40X8Hhttps://www.wallystech.com/Routerboard/DR40X8H-Qualcomm-IPQ4018-IPQ4028-2T2R-Dual-Band-2-4GHz-5GHz-high-power-support-MU-MIMO-802.11ac-Wave-2.html
Featuring with industrial-grade IPQ4018/IPQ4028 chipsetIntegrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio moduleSupport 4.940GHz to 5.825GHz Frequency Range;Support 2.400GHz to 2.482GHzSupport 2 x 5G MMCX Connectors and 2x2.4G MMCX20MHz/40MHz/80MHz BandwidthSupport 11ABGN/ACRoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals The DR40X8H is a compact and powerful 2x2 MIMO solution with high-speed Wi-Fi data rates of up to 600Mbps. It is designed for use in indoor or outdoor locations where strong signal strength is required.Featuring with industrial-grade IPQ4018/IPQ4028 chipset, the can be an excellent choice for your commercial and residential networks. The integrated 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module provide stable signals for long-range wireless applications. It also supports 4.940GHz to 5.825GHz Frequency Range, allowing you to connect with devices from a distance of up to 300 meters (328 feet). The comes with two MMCX connectors and two MMCX connectors. These connectors can be used to connect antennas, amplifiers, repeaters, extenders and other accessories such as power amplifiers or GPS modules (optional). DR40X8H supports 11ABGN/AC channels and provides 20MHz/40MHz/80MHz Bandwidth support, which allows it to handle multiple users simultaneously without affecting performance or throughput rate due to interference issues caused by other devices within range of its transmissions .
