9V 12V推挽式变压器驱动器ZCC6602
2022年11月04日 18:05    发布者:我心随我
9V 12V推挽式变压器驱动器ZCC6602DESCRIPTIONThe ZCC6602 is amonolithic oscillator/power-driver, specifically designed for small formfactor, isolated powersupplies inisolated interface applications. It drives a low-profile, center-tappedtransformer primary from a 2.5 Vto 12V DC powersupply. The secondary can be wound to provide any isolated voltage based ontransformerturns ratio.The ZCC6602consists of an oscillator followed by a gate drive circuit that provides thecomplementary outputsignals to drivethe ground referenced N-channel power switches. The internal logic ensuresbreak-before-makeaction between thetwo switches.The ZCC6602 isavailable in a small SOT23-5 package, and is specified for operation attemperatures from –40°C to 125°C.FEATURES• Push-PullDriver for Small Transformers• Single 2.5V To 12 V Supply• HighPrimary-side Current Drive:– 5 VSupply: 650 mA (max)– 3.3 VSupply: 450 mA (max)• Low Rippleon Rectified Output Permits SmallOutput Capacitors• Soft startand Current limit• Thermalshutdown• Small5-pin SOT23 PackageShort- circuitprotectionOver-temperatureprotection•APPLICATIONS• IsolatedInterface Power Supply for CAN, RS-485, RS-422, RS-232,SPI, I2C, Low-Power LAN• IndustrialAutomation• ProcessControl• MedicalEquipment
