Wallys industrial wifi5 router/IPQ4019 IPQ4029 ,802.11AC 2x2 2.4G&5G
2022年09月21日 17:25 发布者:wallyswifi
Wallys industrial wifi5 router/IPQ4019 IPQ4029 ,802.11AC 2x2 2.4G&5GAPPLICATIONSProfi WiFi hotspot coverageCommercial radio coverageHotel Wireless applicationCountry coverageInternet for passengers (bus, train, plane, …)Security SurveillanceSome special scene applicationFeaturing with industrial-grade IPQ4019/IPQ4029 chipset Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module Support 4.940GHz to 5.825GHz Frequency RangeSupport 2.400GHz to 2.482GHz Support 2 x 5G MMCX Connectors and 2x2.4G MMCX Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth Support 11ABGN/AC Support fixed data rateRoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicalsOur Firmware supports all the modules of Quectel
Absolute Maximum Rating
ParameterRatingUnit
Supply Voltage24V~48V
Operating Temperature Range-40 to +70oC
Storage Temperature Range-45 to +105oC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
SymbolParameter
CPUIPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet2xRJ45
SFP connector1xSFP fiber module connector (optional)
3G/4G connector1xminipcie 3G/4G connector support with two sim card
USB connector1xUSB 3.0 connector
POE24V~48V passive POE
DC Jack24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR256MB~512MB
Radio TX Specifications(5180MHz-5825MHz)
Operating ModeData RatePowerTolerance
1 Chain2 Chains
802.11a6 Mbps27dBm30dbm±2dB
54 Mbps23dBm26dbm±2dB
802.11n HT20MCS0, MCS826dBm29dbm±2dB
MCS7, MCS1522dBm25dbm±2dB
802.11n HT40MCS0, MCS825dBm28dbm±2dB
MCS7, MCS1521dBm24dbm±2dB
802.11acMCS0, MCS10,MCS2025dBm28dbm±2dB
MCS9,MCS19,MCS2919dBm22dbm±2dB
Radio RX Specifications(5180MHz-5825MHz)
Operating ModeData RateSensitivity
802.11a6 Mbps-96dBm
54 Mbps-78dBm
802.11n HT20MCS0, MCS8-93dBm
MCS7, MCS15-73dBm
802.11n HT40MCS0, MCS8-90dBm
MCS7, MCS15-70dBm
802.11AC HT40MCS0, MCS10,MCS20-90dBm
MCS9,MCS19,MCS29-67dBm
802.11AC HT80MCS0, MCS10,MCS20-88dBm
MCS9,MCS19,MCS29-62dBm
Stable networks guarantee for the ongoing continuity of your video surveillance. Our boards could establish a stable connected wireless environment which is critical for a security surveillance system.Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We’re a supplier to Facebook.EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
