100V 输入同步降压最大5A输出电流 ZCC1005
2022年06月13日 15:39    发布者:我心随我
100V 输入同步降压最大5A输出电流ZCC1005DescriptionThe ZCC1005 is a high voltage, synchronous step-downconverter operates over a wide range input voltage 9V to 100V. The ZCC1005 integratesa 100-V 400-mΩ high-side MOSFET.The ZCC1005 delivers 1.5A continuous load currentwith up to 95% efficiency. The ZCC1005 operates with fixed frequency peakcurrent control with built-in compensation eliminates the need for externalcomponents. Cycle-by-cycle current limit in high-side MOSFET protects theconverter in an overload condition.Hiccup mode protection is triggered if the over-currentcondition has persisted for longer than the present time.The ZCC1005 exhibits protection featuresthat protect the load from faults like under-voltage, over-current andover-temperature.The ZCC1005 is available in an ESOP-8package.Features• 9V to 100V input voltage range• 1.5A/5A continuous output current• 95% Peak Efficiency • 400μA operating quiescentcurrent • 100V 400-mΩ high-side MOSFET• Peak Current mode control• 150 kHz Fixed Frequency• Internal compensation for ease of use• Up to 92% duty cycle • 0.8V voltage reference• 1μA shutdown current• 3A/6A cycle-by-cycle current limit• 150ms Hiccup mode short circuit protectionFunction• Thermal shutdown Function• ESOP-8 package• Applications• Charger in vehicle• Battery Chargers• Power adapter
