QCN9074/QCN9024/QCN9072 WiFi Card IPQ6010,802.11ax,2x2 2.4G&5G, OpenWRT
2022年05月27日 11:40    发布者:wallyswifi
DescriptionDR-AP6018-S-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x  DR6018(IPQ6010) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);1 x Enclosure.
Dipole antenna
■  2 x 2.4G&5G Antenna■  5dBi 2.4GHz/5Ghz■ SMA Plug interface ■ Plastic rod of black ■ RoHS complianceEnclosure■  Dimension: 133x 128 x 44 mm■  Aluminum alloy material■ Two Version: DR-AP6018-S-AB (color black)DR-AP6018-S-AO (color orange)■  Support Wally DR6018-SWallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
Absolute Maximum Rating
Parameter
RatingUnit
Supply Voltage
24V~48V(DC Jack)V
Operating Temperature Range
-40 to +70oC
Storage Temperature Range
-45 to +105oC
Operating Humidity Range
5 to +95 (non-condensing)%
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm-Atheros IPQ6010
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot
1x SD Card Slot(Option)
USB /header
1x USB 3.0 Port(Option)
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V~48V power supply
LED header
2.0 pitch pin header
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Nor Flash
8MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
133mm x 128mm x 44mm
