Wallys/QCA9882/QCA9880 802.11ac Dual band 2x2 2.4G/5G FCC/CE
2022年05月27日 11:37 发布者:wallyswifi
QCA9882/QCA9880 802.11ac Dual band 2x2 2.4G/5G FCC/CE Qualcomm-Atheros QCA9880 chipset2.4GHz max 24dBm & 5GHz max 23dBm output power IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n 2x2 MIMO Technology, up to 867Mbps Mini PCI Express edge connector Support the Frequency 4920MHz~4980MHzRoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check(LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC)Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standardsSupports Dynamic Frequency Selection (DFS)
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech com)EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
Specifications
Symbol
Parameter
Chipset
QCA9880
Host Interface
Mini PCI Express 1.1 Standard
Antenna Connector
2 x UF.L
Frequency Range
2.4GHz: 2.412GHz to 2.472GHz
5GHz: 4.920GHz to 5.825GHz
Operating Voltage
3.3V DC
Power Consumption
5W(Max)
Modulation Techniques
OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
Environmental Temperature
Operating: -40°C to 70°C, Storage: -40°C to 90°C
Environmental Humidity, non-condensing
Operating: 5% to 95%, Storage: Max. 90%
ROHS Compliance
YES
Dimensions (W×H×D)
30.0mm × 50.9mm × 3.2mm
RF Performance Table
Operating ModeData RateRX SensitivityTolerance
2.4 GHz802.11b1Mbps-95dBm±2dB
2Mbps-94dBm±2dB
5.5Mbps-92dBm±2dB
11Mbps-90dBm±2dB
2.4 GHz802.11g6Mbps-94dBm±2dB
9Mbps-93dBm±2dB
12Mbps-92dBm±2dB
18Mbps-90dBm±2dB
24Mbps-88dBm±2dB
36Mbps-85dBm±2dB
48Mbps-81dBm±2dB
54Mbps-80dBm±2dB
2.4 GHz802.11n HT20MCS0-93dBm±2dB
MCS1-91dBm±2dB
MCS2-89dBm±2dB
MCS3-84dBm±2dB
MCS4-83dBm±2dB
MCS5-78dBm±2dB
MCS6-78dBm±2dB
MCS7-76dBm±2dB
2.4 GHz802.11n HT20MCS0-92dBm±2dB
MCS1-88dBm±2dB
MCS2-85dBm±2dB
MCS3-82dBm±2dB
MCS4-79dBm±2dB
MCS5-75dBm±2dB
MCS6-75dBm±2dB
MCS7-73dBm±2dB
Operating ModeData RateTX PowerTolerance
1 Chain2 Chains
2.4 GHz
802.11b
1Mbps20dBm23dBm±2dB
2Mbps20dBm23dBm±2dB
5.5Mbps20dBm23dBm±2dB
11Mbps20dBm23dBm±2dB
2.4 GHz
802.11g
6Mbps21dBm24dBm±2dB
9Mbps21dBm24dBm±2dB
12Mbps21dBm24dBm±2dB
18Mbps21dBm24dBm±2dB
24Mbps21dBm24dBm±2dB
36Mbps20dBm23dBm±2dB
48Mbps19dBm22dBm±2dB
54Mbps19dBm22dBm±2dB
2.4 GHz
802.11n HT20
MCS021dBm24dBm±2dB
MCS121dBm24dBm±2dB
MCS221dBm24dBm±2dB
MCS320dBm23dBm±2dB
MCS420dBm23dBm±2dB
MCS520dBm23dBm±2dB
MCS619dBm22dBm±2dB
MCS719dBm22dBm±2dB
2.4 GHz
802.11n HT40
MCS021dBm24dBm±2dB
MCS121dBm24dBm±2dB
MCS221dBm24dBm±2dB
MCS320dBm23dBm±2dB
MCS420dBm23dBm±2dB
MCS520dBm23dBm±2dB
MCS619dBm22dBm±2dB
MCS718dBm21dBm±2dB
2Mbps-94dBm±2dB
5.5Mbps-92dBm±2dB
11Mbps-90dBm±2dB
9Mbps-93dBm±2dB
12Mbps-92dBm±2dB
18Mbps-90dBm±2dB
24Mbps-88dBm±2dB
36Mbps-85dBm±2dB
48Mbps-81dBm±2dB
54Mbps-80dBm±2dB
MCS1-91dBm±2dB
MCS2-89dBm±2dB
MCS3-84dBm±2dB
MCS4-83dBm±2dB
MCS5-78dBm±2dB
MCS6-78dBm±2dB
MCS7-76dBm±2dB
2.4 GHz802.11n HT40MCS0-92dBm±2dB
MCS1-88dBm±2dB
MCS2-85dBm±2dB
MCS3-82dBm±2dB
MCS4-79dBm±2dB
MCS5-75dBm±2dB
MCS6-75dBm±2dB
MCS7-73dBm±2dB
