wifi6-Qualcomm-IPQ6000-2T2R-2-GE-port-MU-MIMO-OFDMA-802.11AX-support-OpenWRT
2022年05月27日 11:36    发布者:wallyswifi
Qualcomm-Atheros IPQ6000Quad-core ARM 64 bit A53s 1.2GHz processor2.4GHz, 2x2 MU-MIMO OFDMA Technology, up to 573Mbps5GHz, 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps2 on board radios (Dual Band Concurrent Radio)Supports Dynamic Frequency Selection (DFS)
Absolute Maximum Rating
ParameterRatingUnit
Supply Voltage12V
Operating Temperature Range-20 to +70oC
Storage Temperature Range-45 to +90oC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
SymbolParameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.2GHz processor
System Memory
DDR3L 512MB 16-bit interface
Nand Flash
128MB
NOR Flash
16MB
Ethernet Port
2x 1Gbps Ethernet Ports
DC Jack Input
1x DC Jack Connector: 12V
Power Consumption(Board Only)
1TD
On Board Radio
2 radios (Dual band concurrent radio)
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 20dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 2x U.FL Connectors, diplexer allows dual band concurrent operation
Frequency Range
2.412~2.472GHz, 5.150~5.825GHz
2.4GHz Data Rate
5GHz Data Rate
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM,1024QAM
LED
4x LED Indicators
USB /Header
1x MicroUSB 2.0 Port
Serial Port
1x Serial Interface 12 Pin Connectors
Certification
TBD
Humidity
Operating: 5% to 95% (non-condensing) Storage: Max. 90% (non-condensing)
Temperature Range
Operating: TBD Storage: -40oC to 90oC
Dimension (Diameter x Height)
100mm x 23.5mm (Without Heatsink)
Radio TX Specifications For 2.4GHz
Operating ModeData RatePowerTolerance
1 Chain2 Chains
2.4GHz
   802.11b1Mbps20dBm23dBm±2dB
2Mbps20dBm23dBm±2dB
5.5Mbps20dBm23dBm±2dB
11Mbps20dBm23dBm±2dB
2.4GHz
   802.11g6Mbps20dBm23dBm±2dB
9Mbps20dBm23dBm±2dB
12Mbps20dBm23dBm±2dB
18Mbps20dBm23dBm±2dB
24Mbps20dBm23dBm±2dB
36Mbps20dBm23dBm±2dB
48Mbps20dBm23dBm±2dB
54Mbps18dBm21dBm±2dB
2.4GHz
   802.11n HT40MCS 019dBm22dBm±2dB
MCS 119dBm22dBm±2dB
MCS 219dBm22dBm±2dB
MCS 319dBm22dBm±2dB
MCS 419dBm22dBm±2dB
MCS 519dBm22dBm±2dB
MCS 618dBm21dBm±2dB
MCS 717dBm20dBm±2dB
2.4GHz
   802.11n HT40MCS 018dBm21dBm±2dB
MCS 118dBm21dBm±2dB
MCS 218dBm21dBm±2dB
MCS 318dBm21dBm±2dB
MCS 418dBm21dBm±2dB
MCS 518dBm21dBm±2dB
MCS 617dBm20dBm±2dB
MCS 716dBm19dBm±2dB
1 Chain2 Chains
2.4GHz
   802.11ax HE20MCS019dBm22dBm±2dB
MCS119dBm22dBm±2dB
MCS219dBm22dBm±2dB
MCS319dBm22dBm±2dB
MCS419dBm22dBm±2dB
MCS519dBm22dBm±2dB
MCS618dBm21dBm±2dB
MCS717dBm20dBm±2dB
MCS815dBm18dBm±2dB
MCS915dBm18dBm±2dB
MCS1014dBm17dBm±2dB
MCS1114dBm17dBm±2dB
2.4GHz
   802.11ax HE40MCS018dBm21dBm±2dB
MCS118dBm21dBm±2dB
MCS218dBm21dBm±2dB
MCS318dBm21dBm±2dB
MCS418dBm21dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS915dBm18dBm±2dB
MCS1014dBm17dBm±2dB
MCS1114dBm17dBm±2dB
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)WEB:https://www.wallystech.com/
