IPQ6018/IPQ6010/IPQ6000 OpenWrt 2.4/5G dual bands 802.11ax Indoor Aluminium alloy material
2022年05月26日 13:40 发布者:wallyswifi
IPQ6018/IPQ6010/IPQ6000 OpenWrt 2.4/5G dual bands 802.11ax Indoor Aluminium alloy material DescriptionDR-AP6018-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR6018(IPQ6010) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);1 x Enclosure.
Dipole antenna ■ 2 x 2.4G&5G Antenna■ 5dBi 2.4GHz/5Ghz■ SMA Plug interface ■ Plastic rod of black ■ RoHS complianceEnclosure■ Dimension: 192x 123 x 44 mm■ Aluminum alloy material■ Two Version : DR-AP6018-AB : Color BlackDR-AP6018-AO: Color Orange■ Support Wallys DR6018
Absolute Maximum Rating
Parameter
RatingUnit
Supply Voltage
24V~48V
Operating Temperature Range
-40 to +70oC
Storage Temperature Range
-45 to +105oC
Operating Humidity Range
5 to +95 (non-condensing)%
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm-Atheros IPQ6010
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
BluetoothCSR8811 BLE 4.2
Nor Flash
32MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
185mm x 116mm
Radio TX Specifications(5180MHz-5825MHz)
Operating ModeData RatePowerTolerance
1 Chain2 Chains
5Ghz 802.11ax HE20MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
5Ghz 802.11ax HE400MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
5Ghz 802.11ax HE80MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
Radio TX Specifications(2412MHz-2482MHz)
1 Chain2 Chains
2.4Ghz 802.11ax HE20MCS023dbm26dbm±2dB
MCS123dBm26dBm±2dB
MCS223dBm26dBm±2dB
MCS323dBm26dBm±2dB
MCS423dBm26dBm±2dB
MCS523dBm26dBm±2dB
MCS623dBm26dBm±2dB
MCS722dBm25dBm±2dB
MCS821dBm24dBm±2dB
MCS921dBm24dBm±2dB
MCS1018dBm21dBm±2dB
MCS1117dbm20dbm±2dB
2.4Ghz 802.11ax HE40MCS023dbm26dbm±2dB
MCS123dBm26dBm±2dB
MCS223dBm26dBm±2dB
MCS323dBm26dBm±2dB
MCS423dBm26dBm±2dB
MCS523dBm26dBm±2dB
MCS623dBm26dBm±2dB
MCS722dBm25dBm±2dB
MCS821dBm24dBm±2dB
MCS921dBm24dBm±2dB
MCS1021dBm24dBm±2dB
MCS1119dbm22dbm±2dB
GPIO Pin Mapping
GPIO Pin Mapping
PinSignalPinSignal
GPIO_0AUDIO_MUTE_BUTGPIO_1QPIC_BUSY_N
GPIO_2MIC_VOL_MGPIO_3QPIC_WE_N
GPIO_4QPIC_RE_NGPIO_5QPIC_DAT4
GPIO_6QPIC_DAT5GPIO_7QPIC_DAT6
GPIO_8QPIC_DAT7GPIO_9WPS
GPIO_10QPIC_CLE_NGPIO_11QPIC_NAND_CE_N
GPIO_12QPIC_DAT1GPIO_13QPIC_DAT2
GPIO_14QPIC_DAT3GPIO_15QPIC_DAT0
GPIO_16MIC_KPD_PWR_NGPIO_17QPIC_ALE
GPIO_18KYPD_HOME_NGPIO_19GND
GPIO_20Boot_Config(PULL_DOWN)GPIO_21MUTE_ON
GPIO_22ADC_RSTGPIO_23WSA_SWR_CLK
GPIO_24WSA_SWR_DATAGPIO_25PWM_LED_RST
GPIO_26Boot_Config(PULL_DOWN)GPIO_27WSA_EN_R
GPIO_28WSA_EN_LGPIO_29PDM_CLK0
GPIO_30PDM_DATA0GPIO_31PDM_CLK1
GPIO_32PDM_DATA1GPIO_33EXT_MCLK2_ADC
GPIO_34MIC_VOL_PGPIO_35LED_5G
GPIO_36PCIE0_WAKEGPIO_37LED_2GS
GPIO_38SPI0_CLKGPIO_39SPI0_CS_NI
GPIO_40SPI0_MISOGPIO_41SPI0_MOSI
GPIO_42BLSP2_SCLGPIO_43BLSP2_SDA
GPIO_44BLSP2_UART_RXGPIO_45BLSP2_UART_TX
GPIO_46BLSP5_SCLGPIO_47BLSP5_SDA
GPIO_48NCGPIO_49Boot_Config(PULL_DOWN)
GPIO_50LED_USB0GPIO_51BT_PRIORITY_PTA11
GPIO_52WLA_ACTI_PTA12GPIO_53BT_ACT_PTA10
GPIO_54Boot_Config(PULL_DOWN)GPIO_55NC
GPIO_56NCGPIO_57NC
GPIO_58NCGPIO_59PCIE0_CLK_REQ
GPIO_60PCIE0_RSTnGPIO_61NC
GPIO_62SD_DETGPIO_63SD_WP
GPIO_64MDCGPIO_65MDIO
GPIO_66SD_LDO_ENGPIO_67NC
GPIO_68NCGPIO_69SPI_CLK_UART_RTSn
GPIO_70SPI_CS_UART_CTSnGPIO_71SPI_MISO_UART_RX
GPIO_72SPI_MOSI_UART_TXGPIO_73USB_OTG
GPIO_74NCGPIO_75Malibu_RESET
GPIO_76NAPA_INT0GPIO_77NAPA_RESET
GPIO_78QTZ_INTGPIO_79QTZ_RESET
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech com)EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
