QCA9880/QCA9882 802.11ac Dual band 3x3 2.4G/5G FCC/CE/IC
2022年05月26日 13:38 发布者:wallyswifi
QCA9880/QCA9882 802.11ac Dual band 3x3 2.4G/5G FCC/CE/IC Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
Specifications
Symbol
Parameter
Chipset
QCA9880
Host Interface
Mini PCI Express 1.1 Standard
Antenna Connector
3 x UF.L
Frequency Range
2.4GHz: 2.412GHz to 2.472GHz
5GHz: 4.920GHz to 5.825GHz
Operating Voltage
3.3V DC
Power Consumption
5W(Max)
Modulation Techniques
OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
Environmental Temperature
Operating: -40°C to 70°C, Storage: -40°C to 90°C
Environmental Humidity, non-condensing
Operating: 5% to 95%, Storage: Max. 90%
ROHS Compliance
YES
Dimensions (W×H×D)
30.0mm × 50.9mm × 3.2mm
RF Performance Table
Operating ModeData RateTX PowerTolerance
1 Chain3 Chains
2.4 GHz802.11b1Mbps20dBm25dBm±2dB
2Mbps20dBm25dBm±2dB
5.5Mbps20dBm25dBm±2dB
11Mbps20dBm25dBm±2dB
2.4 GHz802.11g6Mbps21dBm26dBm±2dB
9Mbps21dBm26dBm±2dB
12Mbps21dBm26dBm±2dB
18Mbps21dBm26dBm±2dB
24Mbps21dBm26dBm±2dB
36Mbps20dBm25dBm±2dB
48Mbps19dBm24dBm±2dB
54Mbps19dBm24dBm±2dB
2.4 GHz802.11n HT20MCS021dBm26dBm±2dB
MCS121dBm26dBm±2dB
MCS221dBm26dBm±2dB
MCS320dBm25dBm±2dB
MCS420dBm25dBm±2dB
MCS520dBm25dBm±2dB
MCS619dBm24dBm±2dB
MCS718dBm23dBm±2dB
2.4 GHz802.11n HT40MCS021dBm26dBm±2dB
MCS121dBm26dBm±2dB
MCS221dBm26dBm±2dB
MCS320dBm25dBm±2dB
MCS420dBm25dBm±2dB
MCS520dBm25dBm±2dB
MCS619dBm24dBm±2dB
MCS718dBm23dBm±2dB
Operating ModeData RateRX SensitivityTolerance
2.4 GHz802.11b1Mbps-95dBm±2dB
2Mbps-94dBm±2dB
5.5Mbps-92dBm±2dB
11Mbps-90dBm±2dB
2.4 GHz802.11g6Mbps-94dBm±2dB
9Mbps-93dBm±2dB
12Mbps-92dBm±2dB
18Mbps-90dBm±2dB
24Mbps-88dBm±2dB
36Mbps-85dBm±2dB
48Mbps-81dBm±2dB
54Mbps-80dBm±2dB
2.4 GHz802.11n HT20MCS0-93dBm±2dB
MCS1-91dBm±2dB
MCS2-89dBm±2dB
MCS3-84dBm±2dB
MCS4-83dBm±2dB
MCS5-78dBm±2dB
MCS6-78dBm±2dB
MCS7-76dBm±2dB
2.4 GHz802.11n HT40MCS0-92dBm±2dB
MCS1-88dBm±2dB
MCS2-85dBm±2dB
MCS3-82dBm±2dB
MCS4-79dBm±2dB
MCS5-75dBm±2dB
MCS6-75dBm±2dB
MCS7-73dBm±2dB
1 Chain3 Chains
5 GHz
802.11a6Mbps20dBm25dBm±2dB
9Mbps20dBm25dBm±2dB
12Mbps20dBm25dBm±2dB
18Mbps20dBm25dBm±2dB
24Mbps20dBm25dBm±2dB
36Mbps18dBm23dBm±2dB
48Mbps16dBm21dBm±2dB
54Mbps15dBm20dBm±2dB
5 GHz
802.11n/ac HT20MCS019dBm24dBm±2dB
MCS119dBm24dBm±2dB
MCS219dBm24dBm±2dB
MCS318dBm23dBm±2dB
MCS418dBm23dBm±2dB
MCS517dBm22dBm±2dB
MCS616dBm21dBm±2dB
MCS716dBm21dBm±2dB
MCS815dBm20dBm±2dB
5 GHz
802.11n/ac HT40MCS018dBm23dBm±2dB
MCS118dBm23dBm±2dB
MCS218dBm23dBm±2dB
MCS317dBm22dBm±2dB
MCS417dBm22dBm±2dB
MCS516dBm21dBm±2dB
MCS616dBm21dBm±2dB
MCS716dBm21dBm±2dB
MCS815dBm20dBm±2dB
MCS915dBm20dBm±2dB
5 GHz
802.11n/ac HT80MCS018dBm23dBm±2dB
MCS118dBm23dBm±2dB
MCS218dBm23dBm±2dB
MCS317dBm22dBm±2dB
MCS417dBm22dBm±2dB
MCS516dBm21dBm±2dB
MCS616dBm21dBm±2dB
MCS715dBm20dBm±2dB
MCS815dBm20dBm±2dB
MCS915dBm20dBm±2dB
5 GHz
802.11a6Mbps-94dBm±2dB
9Mbps-94dBm±2dB
12Mbps-92dBm±2dB
18Mbps-90dBm±2dB
24Mbps-86dBm±2dB
36Mbps-84dBm±2dB
48Mbps-81dBm±2dB
54Mbps-80dBm±2dB
5 GHz
802.11n/ac HT20MCS0-93dBm±2dB
MCS1-90dBm±2dB
MCS2-87dBm±2dB
MCS3-83dBm±2dB
MCS4-80dBm±2dB
MCS5-77dBm±2dB
MCS6-74dBm±2dB
MCS7-73dBm±2dB
MCS8-71dBm±2dB
5 GHz
802.11n/ac HT40MCS0-90dBm±2dB
MCS1-88dBm±2dB
MCS2-85dBm±2dB
MCS3-82dBm±2dB
MCS4-79dBm±2dB
MCS5-75dBm±2dB
MCS6-73dBm±2dB
MCS7-73dBm±2dB
MCS8-69dBm±2dB
MCS9-66dBm±2dB
5 GHz
802.11n/ac HT80MCS0-88dBm±2dB
MCS1-86dBm±2dB
MCS2-84dBm±2dB
MCS3-81dBm±2dB
MCS4-77dBm±2dB
MCS5-74dBm±2dB
MCS6-73dBm±2dB
MCS7-70dBm±2dB
MCS8-67dBm±2dB
MCS9-65dBm±2dB
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech com)EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
