IPQ6018 /IPQ6010/802.11ax 2x2 2.4GHz&5GHz 1xM.2 E key
2022年05月26日 13:37    发布者:wallyswifi
Qualcomm-Atheros IPQ6018Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Absolute Maximum Rating
Parameter
RatingUnit
Supply Voltage
24V~48V
Operating Temperature Range
-40 to +70oC
Storage Temperature Range
-45 to +105oC
Operating Humidity Range
5 to +95 (non-condensing)%
Hardware Specifications
Symbol
Parameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port, 1x USB 3.0 Type-C Port
POE
24V~48V passive POE
DC Jack
12V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 12 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/802.11n/802.11ac/802.11ax, max 20dBm per chain
4x U.FL Connectors
Nor Flash
32MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension (W x H x D)
219mm x 150mm x 16.5mm (Without Heatsink)
Radio TX Specifications(5180MHz-5825MHz)
Operating ModeData RatePowerTolerance
1 Chain2 Chains
5Ghz 802.11ax HE20MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
5Ghz 802.11ax HE400MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
5Ghz 802.11ax HE80MCS020dBm23dbm±2dB
MCS120dBm23dBm±2dB
MCS220dBm23dBm±2dB
MCS320dBm23dBm±2dB
MCS419dBm22dBm±2dB
MCS518dBm21dBm±2dB
MCS617dBm20dBm±2dB
MCS716dBm19dBm±2dB
MCS815dBm18dBm±2dB
MCS914dBm17dBm±2dB
MCS1013dBm16dBm±2dB
MCS1113dBm16dbm±2dB
Radio TX Specifications(2412MHz-2482MHz)
1 Chain2 Chains
2.4Ghz 802.11ax HE20MCS023dbm26dbm±2dB
MCS123dBm26dBm±2dB
MCS223dBm26dBm±2dB
MCS323dBm26dBm±2dB
MCS423dBm26dBm±2dB
MCS523dBm26dBm±2dB
MCS623dBm26dBm±2dB
MCS722dBm25dBm±2dB
MCS821dBm24dBm±2dB
MCS921dBm24dBm±2dB
MCS1018dBm21dBm±2dB
MCS1117dbm20dbm±2dB
2.4Ghz 802.11ax HE40MCS023dbm26dbm±2dB
MCS123dBm26dBm±2dB
MCS223dBm26dBm±2dB
MCS323dBm26dBm±2dB
MCS423dBm26dBm±2dB
MCS523dBm26dBm±2dB
MCS623dBm26dBm±2dB
MCS722dBm25dBm±2dB
MCS821dBm24dBm±2dB
MCS921dBm24dBm±2dB
MCS1021dBm24dBm±2dB
MCS1119dbm22dbm±2dB
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
