wallys QCA9882 QCA9880 802.11AC 802.11AN wifi
2022年05月12日 15:16 发布者:wallyswifi
wallys QCA9882 QCA9880 802.11AC 802.11AN wifi Featuring with industrial-grade Atheros’s QCA9882 chipsetIntegrated with 2x 2 5G high power Radio Card4.940GHz to 5.825GHz Frequency Range2 x 5G MMCX Connectors20MHz/40MHz/80MHz BandwidthSupport 802. 11AC/ANRoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Absolute Maximum Rating
ParameterRatingUnit
Supply Voltage3.3V(MINIPCIE)V
Operating Temperature Range-40 to +60oC
Storage Temperature Range-65 to +105oC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
SymbolParameter
CPUQCA9882
Antenna Connector2 x 5G MMCX connectors
ROHS ComplianceYES
Dimension50mm x 30mm x 16mm
Radio TX Specifications
Operating ModeData RatePowerTolerance
1 Chain2 Chains
802.11a6 Mbps25dBm28dbm±2dB
54 Mbps21dBm24dbm±2dB
802.11n HT20MCS0, MCS825dBm28dbm±2dB
MCS7, MCS1520dBm23dbm±2dB
802.11n HT40MCS0, MCS825dBm28dbm±2dB
802.11acMCS0, MCS10,MCS2025dBm28dbm±2dB
MCS9,MCS19,MCS2917dBm20dbm±2dB
Radio RX Specifications
Operating ModeData RateSensitivity
802.11a6 Mbps-96dBm
54 Mbps-78dBm
802.11n HT20MCS0, MCS8-92dBm
MCS7, MCS15-73dBm
802.11n HT40MCS0, MCS8-90dBm
MCS7, MCS15-70dBm
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech com)EMAIL:sales@wallystech.comWEB:https://www.wallystech.com/
